Throttle Response??
If you agree with me then your best bet would be to get your intake and throttle body ported along with a good tune. You will notice a difference.
I believe Jeremy Formato of Fasterproms.net has a porting special going on right now. Be sure to check him out. He can hook you up with a mail order tune as well if your interested. JJFormato is his CF name.
I tried to tune better throttle response for years and it was futile until we got the throttle rate table. Our 05's are tuned sluggish from the factory.
Read more here. You will need to find a tuner with the latest 2.23 beta. It's a nice difference!
http://www.hptuners.com/forum/showth...+response+beta
and I can still hear that air rush sound before the engine revs. Is that what we are talking about here. On mine the ported TB and tune fixed it.
I told Jeremy formato I hate that delay at the tap of the pedal. He fixed it
by replacing the TB with a ported one and tuned it out. Since then there has been no delay, hesitation or lack of throttle reving at the tap of the pedal. Its gone and I know others hate it as well. I hope GM did something in 08 or 09 bucause in 07 it was still a problem.
EFI Live had that throttle rate table for a while now. Pro tuners knew to adjust it on cars that had the factory sluggish rate settings to make the car feel snappy. It's new from January in HP Tuners.
To prove how long and hard I fought this sluggish throttle, look here!
http://www.hptuners.com/forum/showth...response+table
I was trying since 9/07. I knew something was wrong, and tried a lot of things.
Here is what that throttle rate table does - courtesy of Chris at HP Tuners:
the table is called "Throttle Area Increase Rate" and the short help says "This table controls the rate of increase of desired throttle area, set to maximum to disable."
The value is the amount the desired throttle area (the effective area opened by the throttle blade) is allowed to *increase* per "tick" of time within the PCM.
eg. In the ECM drive by wire works roughly like this:
1. Pedal position is measured
2. Pedal position is translated into a requested throttle area % (Driver Demand Throttle)
3. This is arbitrated against all the other allowed throttle requestors, like Cruise Control, Idle and various forms of torque management and failure modes.
4. the lowest is chosen (if nothing else is active then this will be the Driver Demand Throttle)
5. At this point the ECM knows where the throttle wants to move to and also it's current position. It just has to decide how fast to move the throttle from it's current position to the desired position. This is where this table comes in.
6. If the throttle area is *increasing* this table is looked at and the throttle is moved an amount based on the current position and the table value. If it's 1% then it won't move much this "tick". If it's 100% it will probably move directly to the new position (or as fast as is mechanically possible).
7. The amount of time it takes for the throttle to increase to the new position depends on this table. Small numbers take longer, 100% is the fastest.
So it's a ramp rate
The intent of this table is to make the throttle move slower in low speed driving situations or prevent unwanted driveability issues on smaller engined vehicles in higher gears/low RPM.
This is why usually if calibrated this table will have numbers like 1% or 5% at the lower RPM or pedal positions in low gears. Unfortunately for higher powered vehicles it acts as an unwanted traction control. It also removes that nice crisp response you get in a blown car when you snap the throttle at low RPM.
I also thought about the FAST (Spin's mod) but was told unless I did the performance mods (cam, headers, etc.) like alot of you guys have, for me not to do it. So I at least did the quick and very affordable tb porting to hopefully, at least, take advantage of this.
I cant believe GM would ship cars out that would have the problem.
