need a little help, confused...
Old Aug 28, 2009 | 09:17 AM
fastskyline's Avatar
fastskyline
Default need a little help, confused...
ok been having a problem with my car for a couple months. it throws codes and turns on the check engine light almost every time i drive it. im running LG long tubes with no cats and its tuned with a superchips flashpaq. have had this setup over 2 years with the problems only starting recently. the codes i get are either "low voltage oxy bank 1 sens 1" or "oxy bank 1 sens 1 insufficient switching".
so heres what i have done so far: the wiring harness for the left side rear oxy sensor was melted at the connector so i got a new one from LG and replaced it. still got codes. i switched the wiring for the front oxy sensors ie. unplugged right sensor and plugged it into the left harness, and same with the left sensor. then it threw "low voltage bank 2 sens 1" so i figured aha! its the sensor so i replaced the bank 1 sens 1 with a brand new one from gmpartshouse.com.
STILL throwing the same code! im gonna pull my hair out! "low voltage oxy bank 1 sens 1" anybody have any clue cause im lost...???
