Ceramic Brake Pads for C6
Old Aug 29, 2009 | 10:40 AM
progolfer100's Avatar
progolfer100
4th Gear
Default Ceramic Brake Pads for C6
I am considering replacing my stock brake pads with Hawks high performance ceramic pads. Anyone had experience with this and is it a good idea. Thanks
Old Aug 29, 2009 | 10:44 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I love the HAWKS on my 99 with aftermarket rotors. I considered the HAWKS on my 07 Z06 but had heard that the Hawks are not friendly to stock Z06 rotors...I have not heard that about the stock C6 rotors. I ended up with Posi Quiets on my Z and love them...stop great and almost zero dust. I can tell you if you end up with the Hawks you will be happy. Just make sure the compound isn't going to be an issue with your stock rotors
Old Aug 29, 2009 | 10:48 AM
saplumr's Avatar
saplumr
My Hawk Z pads turned squealy. One day they'll be replaced.
Old Aug 29, 2009 | 10:54 AM
User 81424's Avatar
User 81424
If low dust is your goal the GM ceramics are great.
Old Aug 29, 2009 | 12:44 PM
timd38's Avatar
timd38
I have those also and they work great.
Old Aug 30, 2009 | 11:49 AM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I would certainly be happy to help you out with some ceramic pads.
||--Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 153.03 shipped.
Note: The ceramic pads are for stock, F55 and Z51 applications
Old Aug 30, 2009 | 03:39 PM
HoleInOne's Avatar
HoleInOne
Is that per wheel? Can you turn Z51 rotors? I was told because of the holes, it wasn't advised.
Old Aug 30, 2009 | 03:48 PM
ShinodaVette's Avatar
ShinodaVette
Originally Posted by HoleInOne
Is that per wheel?
That price is what you need for all 4 corners; just pads. That's all I replaced when I did my Z51. I didn't turn the rotors so I can't answer your other question. I highly recommend Kevin at PartsTaxi.com for pads. I've had excellent service from him!
To Ceramic Brake Pads for C6
