"Service active handling"
Old Aug 29, 2009 | 01:17 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Default "Service active handling",,need advice!!
It's been about 3 years since this stupid code came on the display,but I was driving with My Daughter last week and while on the "FREEWAY", the Vette starts to shake a little and slows itself down then says "service active handling","traction control off"!!
I pulled over,,shut it down,,and started it back up with no further problems.
It was a little scary at 70 mph!
Any opinions would be appreciated!
George
Old Aug 29, 2009 | 06:01 PM
1bdasvt's Avatar
1bdasvt
Anybody out there??????
Old Aug 29, 2009 | 11:39 PM
DonEL's Avatar
DonEL
Default Service Active Handling
I had similar occurence on my 05 (but not at 70 mph). Took it to the dealer who found a TSB on the subject. They downloaded and installed a computer reflash that fixed the problem. No recurrence in two plus years.
Old Aug 30, 2009 | 12:22 AM
1bdasvt's Avatar
1bdasvt
Thank You!
Old Aug 30, 2009 | 12:52 AM
Insom's Avatar
Insom
If there is a programming fix for this why was it not implemented on the LS3???
My '09 LS3 is showing this "Service Active Handling" message. Everytime I start the car.. it comes up.
Twice now I've forgotten to turn off traction control and the car out of no where hits the brakes and shows "ABS active".
Any fix for this obnoxious and dangerous problem?
Old Aug 30, 2009 | 11:12 PM
SgtRod's Avatar
SgtRod
This, to me, is the biggest problem with corvettes. You take it to the dealer and its like chasing a ghost. I can tell you a horror story about it but lets think possitive. At least I didnt smash into a semi!
Old Aug 31, 2009 | 12:01 AM
SpinMonster's Avatar
SpinMonster
Anyone have the service bulletin number? Or is it that they simply go to the newest operating system?
Old Aug 31, 2009 | 01:51 PM
Dogue's Avatar
Dogue
Mine (05) just did this today for the first time. Car won't run in 4th (auto) and when you accelerate it's like the tranny is slipping. It went away after restarting the car but I guess it needs to go to the dealer???
Old Sep 1, 2009 | 10:57 PM
2006c6keller's Avatar
2006c6keller
Default Active handling service bullitin
They have a Service Active Handling Service Bullitin out to install Clip, part #19179794, in SWPS connector, TSB #06-02-35-002B - (10/19/2007) A Code of DTC C0710. SWPS = "Steering Wheel Position Sensor". This clip prevents the moving and the loosening of the terminal connector and wire in the which can cause a high resistance condition. This can result in the possible loss of control of the car with the locking of brake(s)?
Old Sep 2, 2009 | 12:13 AM
Insom's Avatar
Insom
is it still the same bulletin from 2007 that applies to 2009 vettes? They haven't fixed this TSB on new cars!?! crazy quality control issue here.
Old Sep 2, 2009 | 08:54 PM
DeaconBlue's Avatar
DeaconBlue
Default Don't feel like the Lone Ranger...
George
Check out the sticky at the top of the C6 Tech section and check out this link: http://forums.corvetteforum.com/c6-t...er-action.html
DeaconBlue
To "Service active handling"
