Wheel Offset Chart (covers high offset & wide wheels)
Wheel Offset Chart (Wide Range)
I made this wheel offset chart with information available from the web. I converted it into a picture and tested it. It will print out and fill up an 8 ½ X 11 sheet of paper. It covers wheel widths from 5 ½” to 15” and back spaces from 3 ¼” to 10”. I went all the way to a 10 inch backspace because that is the width from the wheel mounting surface to the rear spring in a 67 Eldorado. The chart should also be useful to drag racers with narrowed rear ends and slicks. The high offsets should cover all Vette and Mustang applications.
Cody G. Carson
P.S. I would like to have my screen name changed from EldoVetteStang to CadVetteStang as it is in other forums
