The drop in performance is enough to measure. I ran out of fuel at the track one time and had to use 100 octane (might have been 98) and my ET and trap went down. Add to that the fact that was 2x the price of pump gas, I no longer to try to save the last 20 - 30lbs by showing up with an 1/8 tank.
You are right aviation gas is 115 or 130 and for the best part of it most
aircraft run 13.5:1 compression. That would make sense.I know JB is
big on the torco attitive to boost to 100 octane. I presume he tunes for it.
Most Aviation Engines run 8-9:1 Cr. Lycoming/Continental, Turbos run 7.8:1
General Aviation fuel is 100ll, blue, 115/130 Green is only avaliable overseas.
Avgas 115/130 was used years ago in the USA mainly for big radial engine aircraft. For example, the Pratt & Whitney R-4360 Wasp had a 6.7 compression ratio with a 5.75" bore and 6' stroke. They were low reving, but needed the higher octane because of the very large cylinder quench area.
Since the round motors are allmost all gone, the fuel is only avaliable in the Island and South America, where they use them.
You'll want to monitor that intake closely. It has the worst reputation of any IMHO for sucking in debris and deforming under normal operating conditions. Better yet, have your shop check it periodically if they recommended it.
San
Thanks for the heads up. The guy who runs the Corvette shop I had the Vortex installed at has been running his business for over 20 yrs. I figured if he had a bunch of problems with the Vortex, he wouldn't be installing them. I'll be sure to ask him about it though!!!
I've run a Vortex Rammer, it worked good, no problems, that being said I now run an LPE unit
and it's about the same setup, except it has a much better Filter and cone design.
I swapped to 100mm Maf so the Vortex no longer fit.
My bad. I saw "V" and thought Vararam. I haven't read anything negative about the Vortex.
