AC Problem
Old Sep 21, 2009 | 11:46 AM
FRDnemesis's Avatar
FRDnemesis
Default AC Problem
07Z06
AC cycles off randomly and comes back on randomly.
Doesn't matter if its part throttle or half throttle. There is no continuity or trend to the cycling.
The control panel and all controls work fine, or "appear" to be working fine.
Any insight?
Thanks,
Jeff
Old Sep 21, 2009 | 09:20 PM
FRDnemesis's Avatar
FRDnemesis
Originally Posted by FRDnemesis
07Z06
Any insight?
Thanks,
Jeff
Come on, this cannot be the first anyone has heard of this? Any ideas?
-jeff
Old Sep 21, 2009 | 09:48 PM
woulddug's Avatar
woulddug
Mine does the same, does it less if off of AUTO setting
Old Sep 21, 2009 | 09:53 PM
VET4LES's Avatar
VET4LES
More information is necessary. What cycles off, the blower or the compressor. Does the cool air cycle on and off? Low R134 can cause the compressor to cycle. Too much R134 can cause a problem also. Good luck.
Old Sep 21, 2009 | 10:01 PM
woulddug's Avatar
woulddug
on mine it is the compressor. It blows but the air warms up
Old Sep 22, 2009 | 06:42 PM
VET4LES's Avatar
VET4LES
The most likely cause is a slow R134 leak. Sometimes you can add a little and it will work OK. It will not work if you have to much R134 also.
To AC Problem
