NPP rattle
If you have good vacuum then it could be a bad actuator.
If you have low vacuum, then you may have a kink in your vacuum line from the motor to the solenoid, or a leak somewhere.
If you have a mity vac hand vacuum pump to test with you can pull vacuum on each of the actuators and see if they hold vacuum and open and close properly.
Ben
Click Here -> Exhaust Commander D.A.S.H. the revolutionary new bi-mode exhaust controller!
NPP Bi-mode exhaust vacuum retrofit kits -> Exhaust Commander All-in-1 bi-mode retrofit kit.
Clean Your Wheels Easily -> PowerStick Wheel Cleaner
My Online Store -> See all my Bi-mode Exhaust Controller Products!
