clutch spring fixed, now pedal issues!!
Old Sep 23, 2009 | 03:40 PM
GREENTAHOE's Avatar
GREENTAHOE
Default clutch spring fixed, now pedal issues!!
I don't know how long my clutch spring had been broken but I was very familiar with how much pressure it took to press the clutch in and how much pressure I felt as I let it out. I had it fixed today at the dealership and as soon as I got into the car I knew something was wrong. I almost put my foot through the floor pressing on the clutch. On the return I felt substantially LESS pressure as the pedal travelled back up. Isn't this the opposite of what I should feel?? I had the tech look at it and drive it and he said it seemed to feel like every other vette. I then had 2 other guys from the dealership drive it and they said the same thing. I seriously doubt these guys would be blowing smoke up my *** as my father is their boss, but I'm still concerned.
Old Oct 27, 2009 | 01:00 PM
TXAtomic's Avatar
TXAtomic
Don't know if you got your answer, but my understanding is if they fixed or replaced the spring then there should be less pressure/ effort to use the pedal. The spring is there to offer assistance.
I bought my car used and I pretty sure the guy removed the spring becuase the pedal is real heavy. I am looking around at how to add it back. Don't know if you can buy just that part or not.
Old Oct 27, 2009 | 02:06 PM
BillH2121's Avatar
BillH2121
^^^^^That's right - its a clutch assist spring. Provides assistance in both directions.
Old Oct 27, 2009 | 02:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If it feels about like a stock honda Civic's clutch then it's working "right". That is to say, the way it was designed to work.
Old Oct 27, 2009 | 05:56 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Mine doesn't feel like many describe? I looked up under there Sunday and I see 1 big spring, it always clicks when I am letting the clutch out as well.
Old Oct 27, 2009 | 08:58 PM
drivinfast's Avatar
drivinfast
could be its broken so no assist, get up in there and look closely. if you have to replace it is less than $10 and easy to do
Old Oct 27, 2009 | 10:05 PM
tdelena's Avatar
tdelena
St. Jude Donor '12, '14-'15, '17, '20
Use the C5 spring. It is smaller and makes the clutch pedal more stiff.
To clutch spring fixed, now pedal issues!!
