How to get collapsed lifter to pump up?
Old Sep 23, 2009 | 04:39 PM
gath47's Avatar
gath47
Default How to get collapsed lifter to pump up?
After about 500 miles on new lifters I'm 99% sure I've got one collapsed lifter. The ticking sound sometimes will go away after a few minutes of idle, but any rev of the engine will cause it to start ticking again.
Rockers, rods, and compression are all good. Other than pulling the heads to get at the lifters, what are my options to try to get it to pump up and stay pumped up?
Old Sep 23, 2009 | 06:29 PM
c6 batmobile's Avatar
c6 batmobile
Theres nothing but running the engine that will keep it pumped up. Maybe yours is toast.
Old Sep 23, 2009 | 07:05 PM
gath47's Avatar
gath47
From my research, things that can cause intermittent failure of a lifter to pump up:
1. Overall oil pressure
2. Oil delivery issue to the lifter
3. Clogged lifter
4. Sticky lifter
My overall oil pressure is good. There could be a delivery issue due to blockage, contaminants, low level, etc. The lifter itself could be clogged or sticky.
Some of the suggestions I've seen elsewhere are to put a bottle of trans fluid in for a 100 miles. Overfill the oil, run then drain to normal level. Use compressed air to try to clear any contaminants... Can anyone recommend any of these procedures?
Old Sep 23, 2009 | 11:16 PM
inthehunt2's Avatar
inthehunt2
How about using something like Rislone? If it's a "clogged" lifter passage, Rislone (or Seafoam, or others like it) should clean it out. It's worked on my other "old" cars with 100K miles on them... JMHO.
To How to get collapsed lifter to pump up?
