Heated seats
Old Sep 24, 2009 | 01:12 PM
pcanal's Avatar
pcanal
3rd Gear
Default Heated seats
Have a 2006 coupe with heated seats, I would like to disconnect the heat from the seat bottom since I can't adjust them seperatly. I have a bad back & could use the heat with out my but sweating. Thanks
Old Oct 7, 2009 | 06:49 PM
pcanal's Avatar
pcanal
3rd Gear
How about a wiring dia. I'll try to figure it out.
Old Oct 7, 2009 | 07:43 PM
c6 batmobile's Avatar
c6 batmobile
I dont understand your question. Are you trying to fully disconnect the heat or just a portion of it.
You do know that the seats have dual temps and an off button right?
Old Oct 7, 2009 | 09:05 PM
Thrillhouse's Avatar
Thrillhouse
He wants to disconnect just the element in the bottom seat cushion, while leaving the one in the seat back active.
Only thing I can say is pull a seat out of the car and look at how everything is wired. You might be able to cut/disconnect the lower element from the circuit.
Old Oct 7, 2009 | 10:47 PM
c6 batmobile
Oh I understand. All the wires connect in one big azz bundle directly under the seat. Theres about 30 wires in there. You are defenitely going to need a diagram to get only one half of the heat element.
Old Oct 7, 2009 | 10:50 PM
pcanal's Avatar
pcanal
3rd Gear
Yaul have it right just want the bottom disconnected, ok, were can I get a wiring dia. ? Thanks, Pat
To Heated seats
