Water Pump
Old Sep 26, 2009 | 01:25 PM
RCTrucking's Avatar
RCTrucking
Default Water Pump
Can anyone tell me how big of a job it is? My 2006 with 10,000 mi. has developed a leak, looks to be coming from the left side water pump mounting flange!
Old Sep 26, 2009 | 01:38 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
See if you can snug it down. Worst case a new water pump.
Old Sep 26, 2009 | 01:48 PM
RCTrucking's Avatar
RCTrucking
Already done that ! I ck. to see how tight they were, and they seemed tight enough. However i did snug them alittle more hoping it would seal up or slow down to no avail. It's not coming from the typical place buy the shaft as far as i can tell. just a small stream dribbling down the left front side of the eng.
Old Sep 26, 2009 | 01:57 PM
RCTrucking's Avatar
RCTrucking
Default Water Pump
Anyway thanks for your input! Guess i'll tear it apart next week and get alittle exp.!
Old Sep 27, 2009 | 05:43 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Water pump woes
If you find it necessary to replace, you may want to install a Mezziere electric water pump and a lower temp stat. It'll bring your temps down and get rid of parasitic drag at the same time. I got a 160* stat with the Mezziere and it brought my running temps down 30 degrees. I never like looking at the temp gauge and seeing 210-220* when getting caught in a long traffic jam in the summer. I also installed a hi-capacity DeWitts radiator and ALL the temps came down.
To Water Pump
