Wideband Install Help
Old Sep 26, 2009 | 11:35 PM
RagtopMike's Avatar
RagtopMike
Default Wideband Install Help
Any threads of install info out there on wideband installs??? I am in the process of installing a LC-1 with the XD-16 guage.
I have headers with bung installed so that part is done. I am hung up on how to get the wires in thru the firewall?
Any examples of ground used?
I have a 08 coupe with S/C and need the AFR info.
Old Sep 27, 2009 | 12:24 AM
spdmn75's Avatar
spdmn75
if you have enough wire the pass side has a huge rubber plug under the glove box that you can feed the wires. theres also a ground by the right side hood strut
Old Sep 27, 2009 | 01:59 AM
RagtopMike's Avatar
RagtopMike
Default Thanks
The passenger side is where I want to go through so that should work. The instructions call for a engine block ground so I will need to look into that more.
Mike
To Wideband Install Help
