Brake Squeal
Old Sep 28, 2009 | 04:33 PM
okie08vette's Avatar
okie08vette
Default Brake Squeal
Brake Squeal, quick question on my 2008 Coupe with 17k miles on it I have a brake squeal sounds like it’s just the brake pad squealing when the brakes are first applied it’s not very loud, it sounds like its coming from the front right, is this something worth taking back to the dealer and try to get warranty work or should I just but on new pads? If it's new pads what are the best?
Old Sep 29, 2009 | 11:44 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
This is normal for this vehicle. Try to presure wash the caliper to get the dust out. You can also do some hard stops and see if that helps.
Ultimitaley if you decide to change pads, check out the carbotech bobcat 1521.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Old Sep 29, 2009 | 12:07 PM
okie08vette
Thanks I will try what you suggested, and I assumed by the lack of respone that it was pretty normal just very annoying to hear that high pitch noise everytime i touch the brakes, if I do replace them I will go with yours. thanks
Old Sep 29, 2009 | 06:47 PM
Johnny vette's Avatar
Johnny vette
been there done that ..... It took me a while but no more squealing.... rayspetos Quiet brake pads.... I swear by them & cost about 100 dollars for the front . You can thank me later ....
Old Sep 30, 2009 | 06:20 AM
djdonte's Avatar
djdonte
My 07 with 32k on the clock does the same, it comes and goes.... checked the brakes but I have good pad left on all four corners. The owners manual is confusing, first it says squeal is normal due to the high perf brakes, then says squeal means you need new brake pads. I was thinking taking the pads off and applying anti-squeal grease to the back side then reinstalling. Mine sounds like its comming from the back. Really annoying that my 40K dollar car sounds like the 300 dollar beater next to me at the stop light.
Old Sep 30, 2009 | 03:45 PM
okie08vette
I hear that, I am going to look at mine this weekend and see I can just clean them up and get them to stop. Will let you know.
Old Sep 30, 2009 | 04:27 PM
Shortimer's Avatar
Shortimer
No brake noise yet but I've got just 5,900 miles on my '08. Thanks for the info.
Old Sep 30, 2009 | 05:39 PM
beav626's Avatar
beav626
Hey Okie-Is yours Z51? if not I had the same problem on mine (Non Z51 too)
A few laps around Hallett will make your brakes sound just like they should.
I dont hear any squeaks anymore. at 16k miles
Old Oct 1, 2009 | 09:44 AM
Schlitz-C6's Avatar
Schlitz-C6
I have an 05 Z51 and this was happening to my car. GM checked the pads and said they were fine. I found a bulletin on the 05 Z51 on this issue here at CorvetteForum and went back to the dealer. Bulletin said the dealer was to replace the pads at no cost to me.
Dealer then told me my rotors were ruined and could not be turned. I fought with them and in the end GM replaced both the rotors and pads and only charged me $200.
The brakes started squealing the first day I drove her and still do. I intend to replace the pads with someone aftermarket and the problem should go away.
Old Oct 1, 2009 | 12:03 PM
yellowvert's Avatar
yellowvert
I had this when I first got the car. I took off the pads and applied the high temp pad adhesive and it went away for a year or so. Its back but infrequent, goes away immediately with one modulation of the pedal and is currently not my biggest problem! I intend to do them again or replace the pads. The dust drives me nuts with black wheels.
Old Oct 1, 2009 | 05:17 PM
Johnny vette
Default raybestos quiet brake pads
Listen guys..........................Ive fixed the problem for you... Just read my first post and you wont hear and brake squealing . Its your ears....lol
Old Oct 1, 2009 | 11:30 PM
jpee's Avatar
jpee
I have a Z51 with 9000 miles it was squealing, I got GM Ceramic pads from Gene Cully... I never did anything to the rotors... not its perfect.. quiet, and NO break dust!!
To Brake Squeal
