Ceramic Break Pad Advice
Old Sep 28, 2009 | 07:56 PM
jpee's Avatar
jpee
Default Ceramic Break Pad Advice
I need a little advice... my car has the Z51 (only 9000 miles) ..I have been VERY easy on the breaks... Yes I drag race it 2 times a month, but the breaks are cold when I stage it, I have "Line Lock" so on my burn outs the rear pads never get hot....
After a run I an real easy on the breaks and usually take the last turn off (so as not to have to break hard!
I just got GM Ceramic break pads to try and get less break dust .. I have to clean the wheels every time I use the car...
Question.... Do I "HAVE" to turn the rotors or can I get away with just replacing the pads... The rotors look fine no "hot spots" or grooves etc...
I'm just trying to avoid having to turn the rotors as they look fine ? Any suggetions...
Old Sep 28, 2009 | 09:32 PM
BEZ06's Avatar
BEZ06
Hi jpee
Take a look here:
http://www.stoptech.com/tech_info/te...e_papers.shtml
There are a bunch of good write-ups, including:
Pad and Rotor Bed-In Theory, Definitions and Procedures (look at the "Bed-In FAQ" in this section)
Removal of Uneven Pad Deposits From Rotors Using Aggressive Friction Compounds
The "Warped" Brake Disc and Other Myths of the Braking System
The last 2 above have to do with problems you're not experiencing, but they'll give you good info about the process of bedding and pad build up.
After you read all that stuff about different pad compounds, my advice would be:
1. Don't worry about turning your rotors - I don't think they need that at all.
2. Put on your new pads and drive the heck of 'em!!!
Bob
Old Sep 28, 2009 | 09:39 PM
jpee's Avatar
jpee
Bob...
thanks..I'm going to check it out now.. but you sound like you know what your talking about and I "like" the idea of not having to go through having them turned...
Old Oct 2, 2009 | 11:25 PM
BartonekDragRacing's Avatar
BartonekDragRacing
i bought a set of "pronto" ceramic brake pads for the front and rear.. I'll have it on Monday night and I'll test out how much/little brake dust it has. $46 front $35 rear.
Old Oct 2, 2009 | 11:30 PM
Bludog's Avatar
Bludog
I installed a set of GM ceramic pads on my Z51 without turning my rotors at about 9,000 miles. 14,000 miles and no brake issues!
Old Oct 3, 2009 | 01:59 AM
jsbwac's Avatar
jsbwac
I did the Hawk ceramic pads and they are fantastic. They need some heat in them to really grip, but after a few laps they are great, and less dust too. I did not turn my rotors when I put them on and have had no problems.
Old Oct 3, 2009 | 10:08 AM
jimmie jam's Avatar
jimmie jam
i have an F55 (same Z51 pads). at 3,500 miles i changed to GM ceramics. now at 4,600 miles i have had little to no dust issues. BEST $135 i have spent on this ride. you should not have to turn/change the rotors unless you have warping issues.
Old Oct 3, 2009 | 10:31 AM
BigMay60's Avatar
BigMay60
I've got these Hawk Ceramic breaks on my C6 and CTS-V and I love them!
Old Oct 3, 2009 | 11:24 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Hawk Ceramic Pads
I also have a 06 Z51 and I replaced the stock dustmaster pads with Hawk ceramic pads on stock Z51 rotors with 12K miles--no turning of rotors necessary. Just make sure you bed-in the pads after install. Some folks told me it was unnecessary because the rotors were not changed, but I thought it best to bed-in the PADS--it can't hurt.
Old Oct 3, 2009 | 02:46 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
The best and easiest thing I've ever seen is just to scuff the rotors with some sandpaper and the new pads will create their own surface. A lot of times if you don't scuff, you get squeal, from the glazing on the rotors.
Old Oct 4, 2009 | 05:57 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I have a Z51 car as well and changed to GM ceramics at 5K miles. I wiped the rotors down with brake cleaner before the install. Almost at 15K miles now with no squeals and no dust.
Old Oct 7, 2009 | 09:08 PM
BartonekDragRacing
LOL. never heard that term before.
Old Oct 9, 2009 | 03:02 AM
djdinoe's Avatar
djdinoe
That was my mistake. Now my brakes are squeeking after it gets heated up. Embarrassing.
Old Oct 9, 2009 | 11:10 AM
leahsc6's Avatar
leahsc6
Thanks for that info!! Love my cersmics they are great , but have the squeal. The squeal is easier to put up with than the dirty brakes!!!
Old Oct 11, 2009 | 09:07 PM
Gene Culley
We all make mistakes. It is an easy fix
Old Oct 11, 2009 | 09:08 PM
Gene Culley
No problem. If you are trying to fix the squeal at a later date and you aren't replacing pads or rotors, scuff both the pads and rotors.
Old Oct 12, 2009 | 07:21 AM
Gundam's Avatar
Gundam
After installing the GM AC Delco Ceramic Pads, I noticed that brake dust was practically non-existent, but I was still getting terrible squealing (even worse than the Z51 pads)
Followed the brake bedding procedure here:
http://www.zeckhausen.com/bedding_in_brakes.htm
and now the squeal is gone!
To Ceramic Break Pad Advice
Old Oct 12, 2009 | 01:41 PM
bbbeast1's Avatar
bbbeast1
I'll have to agree w/ ya, YLOFEVR! The DUSTMASTERS need to go, in favor of the HAWK ceramic repl pads. Like someone said, it's a daily duty to clean the front(mainly) chrome wheels.
I hadn't thought much about this til now. Havin just purchased my new 08 ZO6 a couple of weeks ago(1200 miles on it now). But, as I've experienced w/ the Z28's wheels and the ceramic pads, The brake dust is all but, eliminated for the most part in comparsion to the regular pads for the 1st 30K miles or so.
Don't have any experience w/ the heat in the rotors/pads vs racing.
Old Oct 12, 2009 | 03:30 PM
Bandit1's Avatar
Bandit1
Old Oct 12, 2009 | 04:34 PM
SgtRod's Avatar
SgtRod
I put the Hawk HPS(not the Plus) and I sound like a train coming to a hault! There is so much brake dust that it starts to look like fragments on my wheels. It changes my wheel color.. and they are black!! Oh and they didn't come with the hardware and now I have a clinking noise when I go over bumps! They GRIP when applied though! Choo choo !
