Two Big Questions
Old Oct 1, 2009 | 06:04 PM
MR.G.'s Avatar
MR.G.
Default Two Big Questions
1. What is the diameter of the sway bars for a standard 2002 Vert? Are they larger diameter cause of convertable chassis? Will they work on the C-6?
2. Will a C-5 differential work in a 05 C-6? If so what is needed to make the swap?
Old Oct 1, 2009 | 08:43 PM
Ragtop 99's Avatar
Ragtop 99
The differential can work, but it is not a direct fit. I've seen a conversion kit that deals with the different attachment points.
