Broken DTE diff!
Old Oct 6, 2009 | 08:57 PM
1SLOWC6's Avatar
1SLOWC6
Default Broken DTE diff!
Went to the track over the weekend just to see what my s/c c6 m6 what do and broke my DTE diff! THIS ALL MY FAULT DO TO A LITTLE WHEEL HOP! Is there anything I can do to upgrade diffs? I purchased the best one DTE had at the time (stage 3 or 4) Some local guys are telling me to upgrade zo6 or a zr1 diff any difference between the two? Any help will be appreciated! thanks in advance
Old Oct 6, 2009 | 10:12 PM
VetteNo2's Avatar
VetteNo2
Have you talked to DTE about this, yet?
Old Oct 6, 2009 | 10:18 PM
1SLOWC6's Avatar
1SLOWC6
I haven't talked to anybody yet just figuring I get some suggestions!
Old Oct 6, 2009 | 10:25 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Old Oct 6, 2009 | 10:27 PM
GetSum's Avatar
GetSum
I know you can upgrade to the Z06 rear RPM makes a kit. But you made need the Z06 trans too. Ive heard stories that it can be done without the Z06 trans. I dont know for sure. Please Keep us posted
Good Luck
Old Oct 6, 2009 | 10:32 PM
Sparo2's Avatar
Sparo2
Wheel hop can kill even the strongest of diffs. It's the #1 diff killer, right next to too much power.
If I were you I'd solve that wheel hop problem asap. A ZO6 or a ZR1 diff would be a nice upgrade but pricey at the same time. If you keep your trans you will need to upgrade the main shaft so you can mate both units. ZO6 shaft has more splines. I don't know what you're budget is but there are quite a few options out there.
Sorry to hear about your diff...I'm in the same boat as you. I'm going the C5 diff route. A whole lot cheaper to replace that a C6 diff.
Talk to DTE and see what they can do for you.
Good luck
Old Oct 7, 2009 | 12:13 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Were You running drag radials?
Old Oct 7, 2009 | 08:50 PM
Ragtop 99's Avatar
Ragtop 99
I'd rebuild your unit (if possible) and focus on shocks and tires if you haven't already done so.
Old Oct 7, 2009 | 09:11 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
stock hp + wh = broke diff. you need better tires not a better rear
Old Oct 7, 2009 | 10:14 PM
TrenAman's Avatar
TrenAman
what causes wheel hop so I am sure to stray from it?
Old Oct 7, 2009 | 10:29 PM
Jim_H's Avatar
Jim_H
Better yet, what prevents it.
I read on here that Bilstein or Koni shocks helped, is that still the thinking? I plan to do Pfadt coilovers and sway bars after my H/C is complete, will that help?
I know the runflats don't help but I'm not ready to give them up just yet.
Old Oct 7, 2009 | 11:06 PM
1SLOWC6's Avatar
1SLOWC6
I was running roadmaster M& H
the unit is shattered! but i do have PFADT shocks!
i thought i did! lol
Old Oct 8, 2009 | 03:12 PM
SubSolar's Avatar
SubSolar
Planning to drag race soon, bone stock LS3 A6. Should I worry about wheelhop and breakage on stock supercars? Should I buy a set of wheels and drag radials first?
Old Oct 8, 2009 | 03:33 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Definitely buy a set of drag radials. Not only will you get much better times but they're also designed to be a lot easier on your car. Granted I do have a lot of horsepower, but with my car I'm cutting 1.4xx 60ft times yet I'm only leaving at around 1300 RPM.
Old Oct 8, 2009 | 04:10 PM
SubSolar's Avatar
SubSolar
Hmm, are many A6 guys breaking their stock rear ends with stock hp and factory tires? I was going to get drag radials later for sure, but didn't want to shell out the money right now when it could be spent on headers or something else.
topend182's Avatar
topend182
If you have a manual, you would be better off with ET Streets (bias ply). The soft compound and the nature of bias ply construction will allow for much more sidewall flex, thus easing the strain on the drivetrain. Allow the tires to absorb the shock of the launch, not the car.
Old Oct 8, 2009 | 04:30 PM
Ragtop 99's Avatar
Ragtop 99
And punt the 19" rims for track use and look into some 17" or 18" to get some sidewall to flex.
To Broken DTE diff!
