Rear alignment adjustment range
Old Oct 7, 2009 | 10:51 AM
yellowvert's Avatar
yellowvert
Default Rear alignment adjustment range
I slide into a curb and knocked the LR wheel out of alignment. Its up and we are trying to determine what has either bent or got knocked out of line. The front of the rear wheel is knocked into a "toe in" position - by maybe as much as 3/4 -1 inch at the leading edge of the tire. We've looked closely at the tie rods and they appear straight. The brackets that attach to the frame also appear in tact.
Is there enough adjustment in the rear suspension to allow it to be brought back into alignment or is there definately something bent? Any ideas?
(I'm getting a couple of other things fixed before I take it into a good alignment shop....just thought I'd look for advice if there is any out there.)
Thanks,
Scott
