Another popping suspension thread
Old Oct 7, 2009 | 01:54 PM
Chaser720's Avatar
Chaser720
Default Another popping suspension thread
Heres the deal. Ive pretty much read every thread on here about popping suspension.
So ive replaced the end links and sway bar bushings with Pfadts.
It was terrible before but now its much better but still some noise.
My twist is every time i take it on some back road for a little fun time , i come back with the suspension popping a lot worse than when i left.
Im hoping that this will narrow down the problem so i can wipe it out for good.
And also what is the correct torque spec on Pfadt end links and bushings. I torqued them to about 75 ft/lbs so that could be a problem there. And the sway bar bushing are torqued to around 50 ft/lbs.
Thanks for the help.
Old Oct 7, 2009 | 09:53 PM
drivinfast's Avatar
drivinfast
Which pfadt end links did you get the teflon lined races called quiet or the regular ones something like $179 vs $299. mine are the quiet and believe me they are.
you got pics of the orientation of the pfadts end links on your car?
Old Oct 7, 2009 | 11:20 PM
Chaser720's Avatar
Chaser720
I payed $225. They said they were normally included in the street sway bar kit. Another vendor starting offering the "quiet" links for $225 a few days after I called Pfadt directly.
I didn't orient them like the directions said. I have the bolts opposite of one another. Ill snap some pics tomorrow and post them up.
To Another popping suspension thread
