Alternative Drive Axle Nut Fix
Old Oct 15, 2009 | 10:55 AM
  #41
Ranger's Avatar
Ranger
Originally Posted by SpinMonster
Its rare that people change my mind about things WHT. I'm in the 118 is best camp but still have a need to know why mine broke....twice.
Post the part number of the ones that broke.
If the first break was to the OEM axle that came stock on an 05 Z51...that part had a design defect.
The question then is what PN was installed that then broke.
It wasn't until 2007 that the design defect was solved enough to handle hard use (moderate abuse).
If your second axle predated the more robust design....
Ranger
Old Oct 15, 2009 | 12:14 PM
  #42
torquetube's Avatar
torquetube
Originally Posted by WHT
There actually was/is a very good reason for wasting all this time. And, it wasn't because it has been so much fun. Among other reasons:
"Follow the Manufacture’s Instructions
To assure the hub assembly is installed correctly, follow the manufacture’s installation procedure. One of the most common mistakes during installation of a new hub assembly is improper torque of the spindle nut. Ignoring these important details will reduce the life of your bearing. Many manufactures have multiple steps to ensure the proper load is on the bearing.
Use a Torque Wrench for the Spindle Nut
It is important to use a certified, calibrated torque wrench. Never use an impact gun to install the spindle nut. The impact gun will damage the axle nut, threads and components. It will also leave your spindle nut under or over torque resulting in hub assembly failure. To ensure proper torque, never use an impact wrench.
Torque Specifications are Important
Ensure that you have the correct torque for the specific vehicle always refer to the included chart or contact the manufacturer. It is important that you properly torque the spindle nut to ensure optimum bearing life from your hub assembly. Under torque of a spindle nut will allow excessive bearing movement causing uneven loading and excessive wear. Over torque of the spindle nut will cause the bearing to overheat, one of the most common causes for bearing failure."
This is irrelevant. The C6 rear axle nut is not a spindle nut, and it does NOT pre-load the bearings.
It's job is to keep the splined shaft from banging back and forth.
Old Oct 15, 2009 | 12:25 PM
  #43
SpinMonster's Avatar
SpinMonster
Ranger
The 05-07 axles were all inferior because they had a thinned area that was later returned to pre-05 thickness. It was like the diff on the 05, redesigned when there was no reason to change it. The C5 axles are the strongest ones and have been setting high 8 sec/low 9 sec passes for longer than the C6 exists. The breaks on my axles at the base of the spindle, had no change from 98 to today. The second axle was the same thickness along the entire shaft. My current C5 shafts have no issue with the insane power levels I'm now at. These axles were bought from the same dealer as the second axle that broke, the same week it broke.
