Do I really NEED these for a cam swap?
I'm contemplating on whether or not I should just buy the cam and the new valve springs (that are required) or just the whole cam package that will come with all of the above.
Price for the package is ~$720
Price for just the cam: $384
Price for the vavle springs (that come with retainers, machined locks, spring baes, and seals) is $255
So that total is $639
But if I get JUST the springs it's $8 each making it $128 (8 * 16)
So that total is only $512
So out of your experience, what should I get along with the cam?
Thanks in advance
what are you gonna do about tuning?
http://www.thunderracing.com/catalog...cid=122&sid=88
Cam Package is the second item, part# CAMPK-PG
- Your Choice of Thunder Racing Camshaft
- Dual Patriot Gold Valvesprings and Ti Retainers
- Thunder Racing Pushrods (7.400)
- Valve Stem Seals
- Additional spring options available below
The cheatr part# is 99-TR-CHEATRLS2-CAM
"LS2 CheaTR" - 215/230 .629/.592 117 LSA.
Off Idle-6800 RPM Power Band.
Broad power range.
Works well with stock exhaust manifolds and catalytic converters.
Stock like idle. Minor tuning required on automatic transmission cars. R
esponds very well to nitrous.
Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
Comp 921 Valve Springs are highly recommended.
Although they recommended the 921, I emailed them and said the Patriot Golds would be even better.
Another forum member recommended the PGs as well.
