Gear change for paddle shift
Signed,
N06
dicky
dicky
Thanks,
Mike
i never had my tune fixed before i got the converter so i never got a good full 1/4 run with just the gears and FAST.
yea since i put the gears in the car it shift's into 4th about the 1000' mark, well that was with the stock sized tires now that i got shorter tires (MT 275/40/17 drag radials) for drag racing it shifts sooner but cant remember how soon. now with my shorter tires, some cool weather, stall converter, and my new tune im hitting 5th right at the traps at 122.5 mph or so, which taller tires would fix this easily.
i dont think you wouldn't gain anything with just the gear swap, maybe most of those guys are comparing those times with there best which was probably in alot better weather also. but i would have to say they are good for atleast .15 to .25 in the 1/4 and to me the gears on the A6 aren't really worth it unless you get a stall converter.
wow you still have stock gears and your hitting 4th at the traps, you must have a pretty high mph. like i said in my other post if i was to do it all over again and especially with you already hitting 4th at the traps i think i would go with the 3.15s
hope this helps
dicky
Mike
Mike
if you get the right stall, gears and of course the tune it will shine at the drag strip. with the addition of the gears, stall, ported FAST 92, retune and my short drag radials i went from a best of 12.18 at 116.x to a best of 11.19 at 121.x with a 1.51 60' on this run i had really good weather.
there is a guy (thesubfloor, he posted on this thread) in CA (not sure how close to you) who has done all different kinds of set ups with gears and a couple of converters and seems to know alot about tuning these cars so that would be a good person to help with the tune.
dicky
