12.36 @ 122 (sigh)
This is the notoriously slick Santa Pod raceway here about an hour outside of London. Not that I'm making excuses, as I'm horrible at launching this car...
Best pass tonight, out of three:
60' - 2.24
330' - 5.59
1/8 - 8.26 @ 92.7
1000' - 10.44
1/4 - 12.36 @ 122.0
Car feels strong up top, but I can't hook it to save my life, even on 335's. Tried leaving at 2k and feathering just to end up breaking loose at 4k again and walking over. Then I tried launching from idle, and while hooking up okay, it was a pretty weak launch. Both were 2.2X's.
I guess minus my absurd sixty-foot shortcomings, the 122mph trap speed is commensurate with a lot of the cars running 11.3-11.6 back in the states. Of course those guys are cutting 1.8's and 1.7's.
Regardless, it was a good time. Gearing seems to be pretty well matched with the size of the rear Nittos, as I'm bouncing the 7k rev limiter just as I'm going through the lights.
I'm definitely familiar with all the posts on proper launch technique, but man is it easier said than done. Especially when you have a cam that hits so hard at about 4-5k. It's like V-tec for Vettes!
But anyway, burnout was respectable. Probably in the 5-6 second range, first gear, probably 5k rpms. Maybe I should take a page from the ranger book and try to grab 2nd. Get them up around 60-70mph in the box, and they'll really warm up.
My advice, seeing how the track is kinda far from you, I would take your car to a deserted road and practice lauching the car. No need to go past 2nd gear while doing this. That's what I did, and when I went to the track I was able to control my lauches better regardless of the track prep.
I notice you said the track you go to is very slick but these tips should help you out a little.
Good luck.
The practice launches are soemthing I need to work with, although it's tough to find good asphalt in rural England. Most roads are old, narrow, gravely, and undulating. The decent ones are only decent because they're in populated areas. Kind of a catch-22. But regardless, I'll get out there and go through the motions. PSI in the tires also stands to come down quite a bit. As far as the track, I didnt see anybody cut hardly anything under 2.0 for 60's, including guys running 11's. For perspective, the buddy I went with is in an STi (awd) on good tires making about 450 lb/ft, is a very respectable driver, and was running consistent 1.9's.
I used to turn 2.2's also, you're not born with the knowledge on how to launch so don't feel bad. Just takes some practice. And those NT's aren't much better than street tires- I tried some 555RII's hoping for good 60's and they were about like street tires. Drag radials are the real key.
This is an excellent resource that I used when I was learning. I think it will help you.
www.rangeracceleration.com
