Has anyone broken into the 11's with bolt-on's and tuning w/ls2 a6 2.56?
I got the tune on a back up pcm and have not changed the cam, trying to save my warranty.
So far, I gone 12.32@116.77 (into a 15mph headwind) on stock tires, with headers, exhaust, vararam, 160 stat and a generic, no dyno tune from Bryan Herter at pcm for less.
Im pretty sure some have. I know for a fact that show room stock on some of these have seen the 11's. Check the list it should give the fastest times with all the included mods that were on the car during that run.
Did you say stock tires? There is some more to be had with your set up adding tires. Especialy if you break traction on 1st to 2nd shift, if you dont then get a retune. Even going to invos helped me. Im in miami with no cartek. I should be at 12.0x after my retune. I dont have a cam, stall, gears, fast or DRs. Thats what some of the faster guys have, rocketing them into the tens.
Oh and drop the headwind..
the point is LS1LT1 went into the 11s pretty far, and martysauto is 20 minutes from my house, if he wants a ride LS1LT1 is down here all the time, and i dont see anyone in the 10s with bolt/ons without Cartek
Let me start by saying congratulations to you for being at the top of the fast list! LS1LT1 is right under you.
You are right. There is no one in the tens without cartek. However there are people with them, not in the tens as well.
I think the OP just wanted to get to the 11s(for now I'm sure). So do I with similar mods. Tires are important too as you pros know. I suggested that he get a retune as well IF he wasn't breaking traction on 1st to 2nd shift. If it could be from cartek then great but I would be interested to see him go into the 11s with just a retune, stock tires and no porting.
I wanted my car tunned by them but didn't have the option.
No, I have nitto drag radials.....on the stock converter they arent really helping much on the launch (low 1.9 60s) but they keep me from going into the wall on the 1-2 shift
not for to much longer though, i just hope my off time, the track being open and the a great DA all line up just right.
back to the OPs ? im in the low 11s but i do have 3.42 gears and a 3600 yank stall. i do belive with full bolt-on (not counting gears and stall) you can get mid to high 11s because i ran a best of 12.18 with just headers, cold air, and tune on stock tires.
I made it down to an 11.70 with stock manifolds and stock converter so even with 'the more basic' bolt ons a solid mid 11 is definitely possible in an LS2.
Originally Posted by SgtRod
Dickey, is a cam a bolt on needed in your mention of mid 11s?
Not sure exactly sure what you're asking here but dicky still has a stock cam and of course any aftermarket cam/valvetrain upgrades are not considered 'bolt on' items.
I have 372 but can't break the 11s!? I'm in Miami though(humid).
LS1LT1 also had the fastest run on a stock ls2.
I need DRs for sure.
My bad about the cam, I got confused. I am no expert but I also try hard not to be misleading in my posts.
Tires help.
if you wait for the right weather you should be able to pull it off, i meet a guy at PBIR last year with just headers, cold air, and tune (not sure what brands or who tuned it) and he was pulling 11.9s all night but it was about 55 degrees.
if you do use drag radials try to run them with about 35psi because i tried them one time with about 20psi and my 60's were not any better that what i got with my runflats. i was told to try the 35psi because the tm comes into effect when i was running the 20psi, so just give it a try should help out.
no problem about the cam, my goal is to have a nice smooth stock idling/ sounding car (most everybody thinks if its quiet then its not fast) run 10s.
Ok, at the risk of sounding stupid, what the h___ is DA?
The trans tuning sounds great, but, with the tcm being in the trans and a pain in the but to change I am kind a stuck with what I got. I don't want to give up that powertrain warranty.
p.s. my car has a weight handicap - me 265lbs. need about 10 more horsepower to go the same times as the average size guy.
Reason: added comment
