battery dead again
Old Oct 24, 2009 | 12:01 PM
btstone84's Avatar
btstone84
Default battery dead again
ok. so this is secong time in 4 days. just bought a brand new battery and it is completely dead. everything is shut off in the car, no lights etc. what is draining the battery
Old Oct 24, 2009 | 12:11 PM
timd38's Avatar
timd38
What year is it? Is it a manual or auto? Did someone put in an aftermarket radio?
Old Oct 24, 2009 | 12:19 PM
kmthor00's Avatar
kmthor00
did you charge the new battery when you installed it? Sometimes they are on the shelves a long time.
Old Oct 24, 2009 | 12:48 PM
btstone84's Avatar
btstone84
It's an 05 auto. Yes. Just had new kenwood navi put it
Old Oct 24, 2009 | 02:02 PM
timd38's Avatar
timd38
My money is on the Kenwood install.
Old Oct 24, 2009 | 02:11 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
No doubt. These cars are finicky about shutting down. I installed the "XM version" of Lockpick and dead battery. I called them, they sent the "non-XM version" and all is well.
Maybe Kenwood has some similar instructions for the Vette.
Old Oct 24, 2009 | 03:15 PM
Altc's Avatar
Altc
Under the battery is the main wiring harness. Check to see if the battery leaked.
Old Oct 24, 2009 | 04:16 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Old Oct 25, 2009 | 12:35 AM
btstone84's Avatar
btstone84
thanks guys
it was the navi. the little blue box that runs the radio and speakers was not cutting off, so the battery was going dead in about 4 hours. it is fixed now, i swapped the boxes out.
Old Oct 25, 2009 | 08:18 AM
timd38's Avatar
timd38
Originally Posted by btstone84
thanks guys
FYI. since you ran the battery dead several times, unless it is an AGM type battery such as an Optima, you have really hurt the battery. Standard flooded SLI batteries are not made to take that abuse. It may not be a problem today, but it will be later and then you will want to blame the battery.
Old Oct 25, 2009 | 06:13 PM
btstone84's Avatar
btstone84
its an optima, and each time i ran it dead, i took back and got a new one.
thanks
Old Oct 25, 2009 | 06:20 PM
timd38's Avatar
timd38
thanks
You did not need to, it is designed to take that type of abuse. Were did you buy it?
Old Oct 25, 2009 | 08:13 PM
btstone84's Avatar
btstone84
o'reilly. i didnt know what it was at first. i thought it was the battery
Old Oct 25, 2009 | 08:23 PM
siffert's Avatar
siffert
Only the Optima yellow tops (deep discharge) are designed for abuse, not the red tops.
Old Oct 25, 2009 | 08:45 PM
timd38's Avatar
timd38
We need to hire you!
You are correct, but Reds will take several deep discharges before you will impact performance.
We make Optima Batteries, in fact the TechTips were filmed in my garage.
Old Oct 25, 2009 | 08:51 PM
siffert's Avatar
siffert
Whatever you say, whom am I (very satisfied yellow top owner) to argue with you.
Old Oct 25, 2009 | 09:14 PM
Hoonose's Avatar
Hoonose
eek: Whatever you say, whom am I (very satisfied yellow top owner) to argue with you. )
Timd38 is our forum battery business insider.
To battery dead again
