Problems opening door...what's the deal...
Old Oct 24, 2009 | 07:21 PM
silvervette05's Avatar
silvervette05
Default Problems opening door...what's the deal...
Here lately i have been having problems opening my door..You can here it clicking trying to open up, but it just takes awhile to finally pop open.I put a brand new battery in my fob, so does anybody know what else it could be...Thanks guys..
Jonathan..
Old Oct 24, 2009 | 08:17 PM
oneblackvette's Avatar
oneblackvette
did you try re-indexing the windows?
Old Oct 24, 2009 | 10:25 PM
silvervette05
i havent done that in a few months..you think that would affect my door not opening(quickly)..
Old Oct 24, 2009 | 11:31 PM
tpereira's Avatar
tpereira
Ive been having the same thing happen lately... sometimes i have to grab the door a few times for it to fully open.
Old Oct 25, 2009 | 01:24 AM
da vette guy's Avatar
da vette guy
a new outside door switch fixed mine
Old Oct 25, 2009 | 08:02 AM
EuroRod's Avatar
EuroRod
I hope this kind of issue is not the first ripple of an electrical tsanami of problems with the 2005 cars. I, too, have had weird things happen..... that simply just shouldn't be an issue with cars costing this much. Usually re-indexing the windows, disconnecting the battery, etc., resolves the problem, but..damn!
Old Oct 25, 2009 | 03:57 PM
silvervette05
I hope its nothng major..I"m gonna re index the windows and disconnect the battery.then cross my fingers and see what happens..
Old Oct 25, 2009 | 04:19 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Jonathan..
PM sent!
Old Oct 26, 2009 | 08:47 AM
mscaggs's Avatar
mscaggs
I had to swap both door handle switches in my 05 and that made it all good. Took me 20 minutes to get in the car one time! The door handle switches are cheap and easy to replace. Good Luck...
Mike
Nashville
Old Feb 10, 2010 | 03:45 PM
jmmy's Avatar
jmmy
Had a little problem opening...thought it was me. Now door won't open. You hear the solenoid trying to go inside the pillar but it doesn't release the door. Both manual pulls work fine and I've changed the FOBs. How can you get inside the pillar to access the works. When I start taking the screws out the mechanism getts loose and I don't want it to fall into the pillar where I can't get it back.
OOps..Same thing when trying to open from inside or out...just hear the solenoid trying to go.
Old Feb 10, 2010 | 09:06 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would think its either a bad door solenoid or a relay that controls it in the door control module.
Old Feb 11, 2010 | 01:18 AM
rorad's Avatar
rorad
I had the exact same problem and the dealership is replacing the door sensors. Covered under warranty.
To Problems opening door...what's the deal...
