how to remove bolster under steering wheel
Old Oct 26, 2009 | 08:07 PM
knkali's Avatar
knkali
Default how to remove bolster under steering wheel
anyone have a diagram , pic, drawing of how the interior piece just below the steering wheel comes off?
Old Oct 26, 2009 | 08:41 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
It has screws at the bottom and hooks under the instrument panel along the top. Remove the screws at the bottom of the panel, it should swing out then pull it out from under the instrument panel.
Old Oct 26, 2009 | 08:52 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Old Oct 26, 2009 | 09:52 PM
Mez's Avatar
Mez
I remember now...the photo shows there are 4 push clips. After removing the screws along the bottom edge, you are going to have pull from the bottom to pop out the clips. You can hardly see it, but there are two tabs on either side of the steering column that once you swing the panel out from the bottom, the tabs will release from under the instrument panel.
Old Oct 26, 2009 | 10:40 PM
knkali's Avatar
knkali
THANKS You guys are awesome!
Old Oct 27, 2009 | 05:59 PM
jimc62k7's Avatar
jimc62k7
Check out these pix if you are still stuck.
http://photobucket.com/NVL_AV8R
To how to remove bolster under steering wheel
