another service charging system thread
Old Oct 27, 2009 | 01:26 PM
Supra-Vette's Avatar
Supra-Vette
Default another service charging system thread
I read through all of the SCS threads and was suprised that none of them mentioned what has to be the most common cause of this.
The alternator wire runs accross the top of the motor and down the firewall directly to the starter where it is connected on the starter stud with the battery wire. If this connection gets corroded which it often does since its about 6 inches off the ground and exposed to water and road debris it will set off the SCS light and prevent charging. I have experienced this twice now. Once it was just loose then it was corroded green.
In other words the alternator is not connected directly to the battery, they are both connected to the positive stud on the starter, so if that connection goes bad no charging will occur.
I would suggest that everyone take this connection off and clean it and put some battery spray on it as preventative maintnance. The starter ground right next to it should be cleaned also.
BE SURE TO REMOVE THE BATTERY POSITIVE ON THE BATTERY BEFORE TAKING IT OFF THE STARTER, UNLESS YOU NEED SOME WELDING DONE DOWN THERE.
Old Oct 27, 2009 | 09:57 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Thanx, I will inspect this area next time the C6 is on the lift for an oil change, or whatever.
Old Oct 27, 2009 | 10:37 PM
Shortimer's Avatar
Shortimer
This is good to know. I've got an oil change coming up and will inspect this connection. Thanks for posting.
Old Oct 27, 2009 | 11:36 PM
csun213's Avatar
csun213
Does your service light come on only during idle and/or at a stop?
Old Oct 28, 2009 | 05:16 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
I'm having this problem since forever!!
I'll give it a shot! Thank you.
Old Nov 2, 2009 | 09:15 AM
Supra-Vette
I have no cats on my car so my light is always on, but my service charging system prompt comes up if the voltage drops below 12 volts for an extended period.
I was also experiencing I would hit the start button and just get a click.
I would also sometimes get the column lock prompt.
This horrible conection can virtually cause any electrical problem and is usually cured with the turn of a wrench.
If your Vette is at a shop or the dealer I guarantee you are buying a new part. They are not going to say yeah I fixed it loose nut no charge. Or even 1 hour labor. They want to get paid they just fixed your Vette you can afford it.
Old Dec 2, 2009 | 08:05 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Well,this explains why I've been getting the same message on the DIC but all charging system tests show the alternator and battery are good. The dealer looked at the car a couple months ago when I had a drive shaft snap and all they said was that the corvette puts out just enough power, it fluctuates, to charge the battery but could not explain the fault. I've had no issues with starting the car or having it die on me but it's been driving my crazy.
thanks
To another service charging system thread
