balancer pulley advice
Old Oct 29, 2009 | 12:41 PM
Schoolteacher's Avatar
Schoolteacher
Default balancer pulley advice
I have read some threads about this subject and just want some advice. I own a 2005 vin 07820. I purchased the car with 22000 miles about a year ago, and noticed a slight wobble, since I have put 23000 more miles on it and have not gotten a rattle or squeal out of the front of the motor. I just looked at the pulley again and it appears to wobble about 1/32" to 1/16".
So my question is to you guys should I stick with the old saying "if it aint broke don't fix it" or should I see about having it replaced?
I'm just looking for your oppinions. The car now has 45000 miles on it. I love to drive it and drive it everyday.
Old Oct 29, 2009 | 06:25 PM
djdonte's Avatar
djdonte
I noticed the same thing on my 07 C6 with 33K miles while flushing the coolant system. Dont know if its a common problem with these cars. I had a LS2 Gto that didnt do that. Also it looks like changing the pulley would be a PITA with the steering rack right there in front of it.
Old Nov 1, 2009 | 04:22 PM
king off the hill's Avatar
king off the hill
Originally Posted by schoolteacher
i have read some threads about this subject and just want some advice. I own a 2005 vin 07820. I purchased the car with 22000 miles about a year ago, and noticed a slight wobble, since i have put 23000 more miles on it and have not gotten a rattle or squeal out of the front of the motor. I just looked at the pulley again and it appears to wobble about 1/32" to 1/16".
So my question is to you guys should i stick with the old saying "if it aint broke don't fix it" or should i see about having it replaced?
hey you dont know how lucky you are if it comes out look out your vin no is the one prone for trouble get checked nowor over 8000 or more
Old Nov 1, 2009 | 04:31 PM
djdonte's Avatar
djdonte
Holy run on sentence batman. What are you trying to say?
Old Nov 1, 2009 | 04:54 PM
king off the hill
No joke look up your harmonic ballancer 2005 on the forum i got mine in time or big ca ca
Old Nov 1, 2009 | 06:43 PM
Hoonose's Avatar
Hoonose
I'm just looking for your oppinions. The car now has 45000 miles on it. I love to drive it and drive it everyday. flag:
It may still fail. If you have no warranty, pay off or kiss your service guy/gal at your dealer, and see if he/she can get it covered by GM for you! It can still fail after all these years. It's a big repair job to install the DEW, diamond embedded washer. But a much bigger bill and dangerous if it goes! This applies to '05 VINs before 11039.
Old Nov 1, 2009 | 07:51 PM
king off the hill
holy smoke robin hes right on on on on
Old Nov 2, 2009 | 12:12 AM
Mike@hpsflorida's Avatar
0Mike@hpsflorida
Former Vendor
i think you are referring to this Gm service bulletin?
Subject: Check Gauge. Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install New Crankshaft Balancer with POA Friction Washer)
Models: 2005 Chevrolet Corvette
with 6.0L Engine (VIN U - RPO LS2)
Built Prior to VIN Breakpoint 55111039
This bulletin is being revised to update the Parts Information and include information on the new POA friction washer in the Service Procedure. Please discard Corporate Bulletin Number 05-06-01-001C(Section 6 -- Engine).
Condition
Some customers may comment on the Check Gauge. Light or the Battery Voltage Low indicator coming on. Additionally, some customers may comment on the accessory drive belt either slipping or being missing.
Cause
The crankshaft balancer bolt may have become loose.
Correction
Install the new crankshaft balancer with POA friction washer and a new crankshaft balancer bolt
Old Nov 2, 2009 | 03:44 AM
Gering's Avatar
Gering
Tolero Apto Victum
My car had the wobbles so I replaced it with one from ATI. I also keep a spare belt in the car for long trips. I have talked to a few people with this problem and it seems to be common. IMO I think at the very least it is worth the piece of mind to change it. Good luck.
Old Nov 2, 2009 | 10:07 AM
Hoonose's Avatar
Hoonose
Condition
Cause
Correction
That's it!
Old Nov 2, 2009 | 10:13 AM
Schoolteacher
So.. will the dealer fix this for free? or am I gonna have to pay.
Old Nov 2, 2009 | 12:42 PM
Hoonose's Avatar
Hoonose
I would do your best brown nosing on this one. This engineering snafu was one big reason I got the extended warranty on my car. It was covered as a prophylactic measure, and I think the bill was in the $800 range.
To balancer pulley advice
