Transmission Carnage pics
Old Oct 30, 2009 | 08:41 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Default Transmission Carnage pics
My rebuilt trans stopped going into 3rd unless I jammed it hard. Would not go in 3rd at all with the car off. Other gears were perfect.
Here is the culprit.
What would cause a 3rd gear blocker ring to crack in half like this?
I'm not looking for a warranty excuse - I'm just wanting to make sure this doesn't happen again to me. I'm on my 3rd trans rebuild in as many months. I hope this is the last time. I have 500 runs in manual Vettes and hundreds of thousands of daily driver miles in a manual trans. Stock clutches always.
Old Oct 30, 2009 | 09:10 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Wow...looks like my knee before surgery... Sorry to hear about this Joe.
I think the cause is you are supposed to be in Vegas with us next week and the car is mad at you....
The only time I've ever heard of blocker rings cracking is due to gear clash, usually from contaminated fluid, but that wouldn't be in your case.......Chuck could probably shed some light for you, give him a call.
Old Oct 30, 2009 | 10:03 PM
tpereira's Avatar
tpereira
i want my click back... when someone says carnage, I expect to see tranny guts everywhere...
Although it sucks your having so many issues
Old Oct 31, 2009 | 12:52 AM
jrose7004's Avatar
jrose7004
That's not carnage!
Old Oct 31, 2009 | 03:19 AM
LS1LT1's Avatar
LS1LT1
Damn, three rebuilds in only a few months, ouch.
Manuals are certainly more fun overall but it's situations like that that make some of us automatic guys feel like we might've made the better choice.
Old Oct 31, 2009 | 03:37 AM
TTRotary's Avatar
TTRotary
Sorry to hear of the troubles Joe, that sucks. Is it the same shop all three times?
If these are aftermarket units, you may want to consider a low mile used one out of a donor car. They may be better assembled (since your factory unit lasted several years).
Old Oct 31, 2009 | 06:55 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I changed rebuild shops on the one in the car now to a local shop that came well recommended.
I have to say with hindsight... I should have bought a brand new trans. It wasn't that much more money. That is my advice to those who have trans problems.
My original trans was fine - when my diff blew it bent the output shaft so I figured then was the time to upgrade to a reinforced manual trans...OEM was much better for me.
Old Oct 31, 2009 | 06:58 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've been working on advertising this week....the headline is important.
Who would even look at a thread that said "cracked 3rd gear blocker ring"? So what. Dog bites man. Not news. Man bites dog. News.
And the search feature will find 3rd gear blocker ring for posterity if we can get some good info posted here.
My hope is someone with some experience in this arena will see the headline be curious and step in with some salient comments.
Meanwhile the smart aleck comments keep the thread on the first page.
Oh...and so you don't think I cheated you or anyone else from the train wreck you were seeking, here's some Diff Carnage pics that caused my trans carnage issues.
Old Oct 31, 2009 | 07:25 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've got my SEMA badge in my bag....but we're moving our hotel next month and work is too nuts to steal away. Have fun buddy and send me some pics of anything cool! (that is if you can steal away from the Subaru section with your son to take some Vette related pics)
Old Oct 31, 2009 | 08:53 AM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
There really does seem to be some sort of curse with the T-56's 3rd gear. My tranny was completely rebuilt and went back in the car less than 500 miles ago. I'm already crunching on the 2-3 shift, and at any kind of high RPM, it's a chore to even engage the gear.
Old Oct 31, 2009 | 09:03 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Good post...this is what I'm after.
I am seriously wondering if there was a batch of bad blocker rings produced or something.....both of my transmissions built 4/09 and again 6/09 had 3rd gear go out within 2000 miles, and coincidentally, my racing buddy has the EXACT same problem in his rebuilt transmission that was rebuilt 6/09.
I'm very concerned about this transmission too....I don't want to give up racing (I've raced for years and years and NEVER had a trans problem) but I cannot afford to keep replacing these transmissions.
Old Oct 31, 2009 | 09:11 AM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Same here. I just went into mine for $1100 in parts, and $800 in labor. Factoring in the time I had to wait to round everything up, I'd have been better just picking up one of the used Z06 transmissions in the FS section right now.
In fact, as concerned as I am, I may still do so anyways to have it on hand for when this transmission inevitably breaks again. Or if the '05 diff goes, which is more of a 'when' than 'if', and happens to take the output shaft with it.
As far as your blocker ring splitting, perhaps there was a metallurgical issue with that component during production, and whatever component it rides on happened to expand/contract under temperature change, causing it to crack.
Old Oct 31, 2009 | 09:30 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I see from another post that you're having trouble with your clutch master and getting air in the clutch hydraulics. I'm 99.999% sure that's your trouble...the trans shop I used this time said a clutch not properly releasing is usually the cause of broken blocker rings - that or power shifting. These trans just can't take that kind of abuse.
In my case I have the stock clutch that works perfectly and I've not changed my shifting - if anything I shift slower with these transmissions trying to baby them. I've never power shifted, I always use the clutch.
I would NEVER buy a used trans, with the trouble I've been having with rebuilts....who knows what kind of abuse a used trans has had on it. It's not like these transmissions are a 2 hour RnR job...it's a big expensive job. If this trans goes I'm chalking up my losses as experience and buying a new trans.
I am seeking knowledge to see if others have this problem and importantly how they solved it. Stopping racing is a solution but not one I want to execute just yet.
By the way, putting in a C5 rear is a good idea BEFORE you blow your rear. You can always sell your rear to an automatic guy, they hold up behind an automatic. When you blow it, it's just a greasy door stop as shown above.
Here's a how to:
http://forums.corvetteforum.com/c6-t...-write-up.html
Old Oct 31, 2009 | 09:34 AM
Craigster05
John is set....I am looking for goodies for the upcoming "Rocky Mountain Forced Induction Land Rocket"...
Old Oct 31, 2009 | 11:00 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
How does the linkage and shifter box for play??? They seem worn out when new and after some miles they get very bad.
Carrol Smith in the book Engineer to win said something like this. Most transmission problems start at the linkage....
Randy
Old Oct 31, 2009 | 11:25 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Randy
My factory shifter (40k miles) feels ok to me - I don't like the notchy feel of aftermarket shifters.
I know in the old days with the 4 speed external linkages with all the adjustments, those could be messed up or bent and ruin the trans. I thought the new internal rail shifters were pretty much good to go forever?
I didn't blow shifts or powershift to bust these trans. They just didn't hold up. I will say they both seemed to break at the track, not daily driving, but my factory transmissions never broke under equal or harder usage. And both times, 3rd gear went out. I didn't get to see the parts on the first rebuild, but, the symptoms were similar. Except with the first time, if I shifted really really slowly into 3rd, I could do it. With this cracked ring, it WOULD NOT go into 3rd unless you jammed it really hard.
Have you seen problems with the shifter linkage/box wearing out?
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
I see what you mean, Joe. I have known that there were clutch related issues for awhile, but the reason it seems like there are independent issues between the two is that fact that it's only 3rd gear. I can only assume every gear would have similar issues if the clutch were the *only* problem.
To Transmission Carnage pics
Old Oct 31, 2009 | 11:32 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I have heard three trans rebuilders (including 2 well known on this board) that if there are clutch release problems trans problems are soon to follow. The syncros (of which the blocker rings are part of) just aren't strong enough to do the job when the clutch isn't released properly.
In my case, I'm religious with clutch fluid, it feels perfect just like it did on day one. I don't think clutch problems are causing my trans problems as that very clutch was working perfectly with my original trans that was damaged by the rear above.
If you're having clutch problems you must get them addressed before you ruin another trans. That's for sure.
But your point that it always seems to be 3rd seems valid for sure!! Maybe it's just the weakest syncro????
Old Oct 31, 2009 | 01:16 PM
saplumr's Avatar
saplumr
Have you considered talking to RPM? They did my trans and diff. From what I saw while there, they can make anything almost break proof.
Old Oct 31, 2009 | 01:58 PM
Skunkworks's Avatar
Skunkworks
If you buy a new trans have you considered upgrading to TR6060 vs. T56?
Mike
