100Lb Injectors for LS3 LS7
Old Oct 31, 2009 | 09:09 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Default 100Lb Injectors for LS3 LS7
We just came out with these , They flow 100lbs at 58PSI ! Exact fit no mods except tuning. Dead times are provided for your tuner. These are High impedance and work with your stock computer!
We also have these in sizes 42 to 100lb and the same in LS2 injectors. No more wire adapters, rail spacing or not being able to use your rail covers.
http://fuelinjectorconnection.com/sh...&productId=214
Old Nov 1, 2009 | 06:53 PM
JnJSpdShop's Avatar
JnJSpdShop
Are these modified stock injectors? If so any discount for sending cores in?
Old Nov 1, 2009 | 07:14 PM
FICINJECTORS
Supporting Vendor
these are modified 60lb ZR1 injectors.. The stock ls3 injectors can only go to 60 @ 3 bar.. The only cores we will give credit for would be from a zr1 or the caddy v series
Old Nov 1, 2009 | 07:47 PM
SpinMonster's Avatar
SpinMonster
You may want to update the advertised statement that they are LS3 and LS7 injectors
Product Information:
Only available here This is the exact injector that came with the LS3 LS7 LS9
on your web site by saying they are LS3/LS7 'size' being a shorty injector but that they 'are' the ZR1 injector.
Great product saving the harsh realities of resistor boxes.
Old Nov 1, 2009 | 07:59 PM
FICINJECTORS
Supporting Vendor
the zr1 injector is the same case as the ls3. 40mm o ring to o ring,, I changed it to say the injector is the same size as the injector that came with the ls3..
thanks
Old Nov 1, 2009 | 10:09 PM
SpinMonster
thanks
Yes, shorty forty's.
Old Nov 1, 2009 | 11:32 PM
Mike@hpsflorida's Avatar
0Mike@hpsflorida
Former Vendor
wow nice set of injectors, you wouldnt happen to have somehting like this in a LS1 style injector
Old Nov 2, 2009 | 12:10 AM
FICINJECTORS
Supporting Vendor
here ya go.. we have these in the ls1 kit from 42 to 103lb high impedance for use with the stock computer
http://fuelinjectorconnection.com/sh...&productId=215
Old Nov 2, 2009 | 12:16 AM
0Mike@hpsflorida
Former Vendor
awww thats cool you have made adapters to make the shortys fit.
Old Dec 8, 2010 | 07:54 PM
bookemdano's Avatar
bookemdano
jon from FIC does one hell of a job with them injectors, i purchased a set of brand new shorty 73# injectors for my Goat and could not be any happier, and his prices can't be beat.
no spacers, or connectors needed, since they are BOSCH injectors tuning them was a piece of cake.
My Goat is my guinea pig, and it makes more power N/A than my 09 Z06,
but the vett is still a virgin, for now....
To 100Lb Injectors for LS3 LS7
