Help "Please" Low Beam light out
Old Nov 2, 2009 | 06:59 PM
skyskibum's Avatar
skyskibum
Cruising
Default Help "Please" Low Beam light out
The low beam light is out on the right side of the car... obviously check the bulb right, I did and replaced it with a new bulb still nothing. The other lights within the headlight work fine. Could this be an electrical problem somewhere, or are there any other parts within the headlight itself I need to replace? any advice would be greatly appreciated!
Old Nov 2, 2009 | 08:50 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
The "low beam?" That's a HID unit, not a bulb. You probably replaced the high beam, that's a bulb. The dealer can replace the HID for you.
Old Nov 3, 2009 | 08:11 AM
skyskibum's Avatar
skyskibum
Cruising
Thank you for your input. I found the problem, it was the low beam HID, first the bulb was bad (you can't just replace the bulb) but the main problem was the right side HID has its own fuse, the fuse was blown. After the fuse replacement everything is fine..... hope that might help someone else in the future.
To Help "Please" Low Beam light out
