i am need of some info. i just bought a set of used Z51 sway bars from a very nice forum member... my mistake was that i didnt check the size that i had on my car!! i bought my 06 with 4500 miles last year. the previous owner i have found out tonight upgraded his sway bars! after i took off the rear bar and put the new one on i measured the old bar against the new one. they were exactly the same! i checked the front and they were the same also.. the car is a base coupe with the f55 setup it has the mag ride suspension. so my question is this: what size difference is there between the base coupe and the Z51 when it comes to the sway bars? and if i can find a set of Z06 sway bars am i going to see that much of a difference?
C6 Base Front Sway Dia (mm) 25.5
Rear Sway Dia (mm) 17.5
C6 Z51 Front Sway Dia (mm) 31.0
Rear Sway Dia (mm) 25.6
C6 Z06 Front Sway Dia (mm) 31.0
Rear Sway Dia (mm) 27.9
Unless you're going with a wide rear tire the Z06 rear sway may be a bit much. I went with Hotchkis bars as the rear is adjustable.
If you have a base car, the Z51 rear bar is a nice upgrade and I agree with the other comment that the ZO6 may be more than you can use. Using the Z51 Rear bar and keeping the stock base front bar gives you a nice ride with improved control.....
do you thinkthat i should replace the springs also? the guy i bought the sway bars from has the springs also. and how can i tell before i buy the springs which ones i have on just in case they were replaced also
The relationship of front vs. rear springs on all but the Z51 option is close to the same. Assuming that the previous owner didn't change the springs, your front to rear ratio is on par with the Z06 and ZR1. Considering that the ZR1 also has the mag shocks (F55) it would be prudent to keep the same relative spring ratios. If you do decide to change springs, don't bother with the rear as it's nearly identical to the Z51 already.
I intend on upgrading to the Z51 sway bars also as I have a base 1LT 07 coupe! So you are saying to just replace the rear bar and not the front for best results?
Sway bars do not impact the ride -- just lateral control / handling. -- --
I have a 2007 with F55. I took my car to Dick Guldstrand and had the
F51 sway bars installed and had the car corner balanced. The ride is a tiny bit stiffer, but the cornering is just an amazing improvement. On the track you can get into the corners a little later and come out a little sooner without exercising the suspension. Great mod!
Yes, please see my other post, hit the wrong button.
Well the best way to find out if you don't have a Z5I optioned car is try this out. You may be surprised just how much bars do impact your ride quality.
The sway bars will not impact ride quality IF both tires (left and right at that end of the car) hit the exact same bump at the exact same time, since then the swaybar is just rotating in the mounting bushings. However since this almost never happens, anytime the right and left tires hit different bumps, the swaybar flexes, so a stiffer bar will give a firmer ride.
So I guess we both agree ride quality (firmer ride) is impacted by installing stiffer bars. That was my point all along, however, I think you did a much better job of explaining why than I did.
Wow... I wanted to stiffen my base ride and eliminate body roll so I found a set of z06 bars and threw them on. Only to hear that z51 rear bars are better.. NOW I hear that the base rear bar is better. Can someone put a rest to this?
Let's do categories. Those that have had more than one set up can fill them out.
1) Stiffness over bumps
2) Body roll/steering response
3) Faster around the corner.
How does that sound guys??
Just to add something... I installed the bars with the OE bushings and went through a local curve pretty fast. After installing the PFADT bushings in the front(only) I smoked that curve and felt much more planted.(before and after was one day apart)
What wheels and tires are you runnning? A local Z06 roadracer here had his car corner-weighted and aligned and the rear sway bar was replaced with a base C6 sway bar. He swears by the change and can't break the rear end loose. I swapped out my suspension and sways at the same time so I don't have an objective "sway bar only" comparison. I also installed the Hotchkis sways.
As I said above, I made the Z51 sway bar change on a F55 and the ride changed. When the suspension is exercised, you'll notice the stiffness right away. The four corners are continuously flexing to some degree and that is telegraphed to the ride quality change. I spend more driving time in the Tour Mode than I did before the change. Sport mode diffidently is tighter and track friendly. This is an inexpensive Mod, however, if yor not putting your car on the track, don't mess with it.
San
Hey bud,
Im running stock wheels with stock sized invos and 1/4 spacers. I wanted stiffness so went with the z bars but may put my base back on the rear now. Was that the best set up?
I also heard from an expert that a Z06 is faster around the track with a z51 sway in the rear than with the z06 bar.
The local Z06 racer here swears by it and thought the suspension tuner was crazy when he wanted to install the base C6 rear sway bar.
