Just installed a Magnaflow #15884 Catback X-Pipe Exhaust System on my 2007 C6 Corvette. Very simple system to install with very few adjustments to make the tips align. The only remaining problem is, the the tips are not centered in the opening. Seems to be more clearance on the left compared to the right. Has anyone else noticed this, are am I just being to ****??
LKicklight
Do you have the same amount of clearance on either side of . the valance panel? Mine is about an inch off on the left side as compared to the right. They are level from the rear and pointed straight out...
LKicklight
My Magnaflow's are centered in the valance. You should be able to adjust the location of the pipe the tips attach to by twisting the muffler where it connects to the over the axle pipe. You may have to realign the tips afterwards.
