i was just wondering if the dual mode exhaust was able to be programmed so that it could be changed from activating at the factory setting of 3500 rpm to a lower RPM.
I have NPP from the factory and I am more then happy with 100% ,99% of the time, we added mild2wild, I wanted it open at idle and take off, opening at 3000 or lower does not give me the impact I need.
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
The factory Npp system is not programmable. It is set by GM and is not adjustable.
Many people like the npp to open earlier than the factory settings. That's where the Ultimate Exhaust Commander comes in. It allows you to set the rpm that the npp system opens at. You can user select from 1800-3500 rpm for a factory car. You also get the ability to go full open and factory rpm open mode.
Most people like to set it to around 2000-2200 rpm, that way the npp system is open for the maximum amount of time with ZERO drone.
If anybody needs any additional info, feel free to contact me anytime.
