cruise control
Old Nov 8, 2009 | 08:08 PM
USA TOY 2's Avatar
USA TOY 2
Default cruise control
I could not get the cruise control on my 05 M6 to engage today, any clues?
Old Nov 8, 2009 | 08:45 PM
Vette_DD's Avatar
Vette_DD
Dealer had to replace the BCM on my 06 coupe when the cruise control went out.
Others here had problems with the brake pedal. Try lifting the brake pedal with the top of your foot - see if that fixes it.
Old Nov 8, 2009 | 08:52 PM
USA TOY 2's Avatar
USA TOY 2
JimTN,
Thanks for the response, I will try that and see if it works.
Old Nov 8, 2009 | 09:45 PM
Shortimer's Avatar
Shortimer
This may not apply in your case ('05 C6) but I had a 2001 coupe with no cruise control. The GM tech found a bent pin in the wire harness. The repair was under warranty. Good luck with yours.
Old Nov 8, 2009 | 09:59 PM
USA TOY 2's Avatar
USA TOY 2
I have an extended warranty and hope it is a simple fix.
Thanks for the help.
Old Nov 8, 2009 | 10:32 PM
HANNY's Avatar
HANNY
hand brake (which you should notice on the dash) or more then likely the foot brake stuck. Easy to tell just go look at the tailinghts
Old Nov 11, 2009 | 12:19 PM
Khalid_1's Avatar
Khalid_1
Interesting.
The experience of you guys are awsome !
Today I had no cruise control. I checked the fuse (No.17 or 18 cant remember) but it is okay. I will check the break padel tomorrow.
Thanks,
Khalid
Old Nov 12, 2009 | 07:07 PM
USA TOY 2's Avatar
USA TOY 2
I tried the brake handle today then took it out for a spin, tried hoding up the brake pedal while trying to engage the cruise control and still no luck....
Old Nov 12, 2009 | 10:35 PM
nowheelie's Avatar
nowheelie
Another possibility is the switch on the clutch pedal.
When you're not pressing the clutch pedal, the arm presses a push button. If the button is not adequately pressed in cruise control will not engage. It doesn't seem to take much.
I added a 0.5-1mm shim on much clutch arm to keep it pressed. I don't use cruise control, but because the switch was "malfunctioning" (not pressed fully) a check engine light came on.
Onstar diagnostics informed me it was a cruise control malfunction, not critical, should be looked at.
Ever since I shimmed it... no problems.
Old Nov 12, 2009 | 10:50 PM
Boat Racer's Avatar
Boat Racer
Another thing to try is just disconnecting the negative terminal of the battery for a couple of minutes to see if it will reset it self. I did that and it fixed that problem for my '07 and it hasn't resurfaced for over a year now. Good luck!!
Old Nov 12, 2009 | 10:56 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old Nov 14, 2009 | 09:10 AM
USA TOY 2's Avatar
USA TOY 2
I sincerely appreciate the responses, I will try them today
To cruise control
