Parking Brake Reconnecting Question
Old Nov 11, 2009 | 09:30 PM
Chaser720's Avatar
Chaser720
Default Parking Brake Reconnecting Question
So just did a slave and master cylinder swap as well as fluids so I had to pull the rear end.
Now my problem is the parking brake will not engage (like at all). From a 1mph roll it will not stop the car. It has some tension on the handle but not nearly what it was.
The car was worked on by me and two friends so I personally did not disconnect the brake so not entirely sure I hooked it up correctly.
Anyone have any pics of a stock untouched one as well as how the line is run. I do admit that i didn't connect the metal square about 1 1/2 feet from the end to anything (pretty much because I don't know where it went).
Any help would be great.
Old Nov 13, 2009 | 09:59 AM
Chaser720's Avatar
Chaser720
Just some pics of someones stock connections and where the line runs would help a lot.
Old Nov 16, 2009 | 03:33 PM
Chaser720's Avatar
Chaser720
Anyone? Just some stock pictures. Please
Old Nov 18, 2009 | 11:35 AM
Chaser720's Avatar
Chaser720
Just a piture of how it hooks up in the rear is all i need.
Old Nov 23, 2009 | 01:45 PM
Chaser720's Avatar
Chaser720
Snap and upload is all i ask.
Old Nov 23, 2009 | 01:53 PM
Chaser720's Avatar
Chaser720
Oh here you go
Old Nov 23, 2009 | 01:54 PM
Chaser720's Avatar
Chaser720
Why thank you.
Old Nov 24, 2009 | 05:00 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
This is why it isn't working. You need to bolt the square piece back up to the bottom of the fiberglass tub. It is almost straight up from where the torque tube and tranny meet.
Old Nov 25, 2009 | 04:56 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Why thank you.
your welcome!!
Old Nov 27, 2009 | 04:46 PM
Chaser720's Avatar
Chaser720
Will look into. Thanks
To Parking Brake Reconnecting Question
