Higher Gear Ratio? Why?
Old Nov 17, 2009 | 09:39 AM
ALLBlackC6's Avatar
ALLBlackC6
Default Higher Gear Ratio? Why?
I dont really understand why people would want lower gear ratio's. I have 453RWHP and 1st and 2nd gear already require throttle control to avoid spinning like crazy, lower gear ratio would only make 1st and
2nd gear more uncontrollable. I can't imagine why I hear guys on the forum talk about 4:10's. The beauty of my Corvette compared to these hopped up imports is that I can carry my gear so much longer.
My car is 05' Z51.
Is it only for 1/4 mile drag racing? If thats the case I completely understand, but as far as street use, it makes no sense. I hear people say 4:10's feels like extra 100HP, that may be true if you want to spin like crazy, do you guys see my point? Especially on the higher HP vettes.
Old Nov 17, 2009 | 10:10 AM
PeterM's Avatar
PeterM
My car is 05' Z51.
I agree. I had 410s installed on my modded 08 MZ51 (495RWHP) and it was ridiculous; I found myself shifting into fifth gear as I entered the traps.
I recently had 390's installed, and they did the trick. I still have enough low end torque to keep the cam happy, and rolling along the highway is a lot of fun (there are a few really nice Sweet Spots).
As far as having fun at a red light, tires are key. With the correct rubber, the car is killer.
One thing I will emphasize is -- make sure you pick the right shop to install the gears! This is one mod that can turn into a real gut-wrenching epic if you visit the wrong shop. I learned that lesson the hard way.
Old Nov 17, 2009 | 10:32 AM
NYC6's Avatar
NYC6
My car is 05' Z51.
Im not a big fan of gearing down a street car. My car makes 522rwhp. Cars may holeshot me off the line but Im usually able to reel em in in short order and go by them with authority. I find that more satisfying anyway. Im on stock Z06 tires and am able to launch pretty good. And when we take long road trips Im not stopping for fuel as fast as hole shot special cars.
Old Nov 17, 2009 | 11:27 AM
Ragtop 99's Avatar
Ragtop 99
I dont really understand why people would want lower gear ratio's. I have 453RWHP and 1st and 2nd gear already require throttle control to avoid spinning like crazy, lower gear ratio would only make 1st and 2nd gear more uncontrollable. I can't imagine why I hear guys on the forum talk about 4:10's
First off, it sounds like you need better tires, but lets set that aside and accept whether you have 3.42s or 4.10s, you will spin 1st and 2nd. What about 3rd and 4th? With 3.90s / 4.10s you will pull through those gears quicker and get to peak HP sooner. You will be faster from a roll with 3.90s / 4.10s than with 3.42s. The car will also be more responsive around town at low rpms (e.g. 2500 rpm) with gears.
When you launch the car hard, do you take off in second gear, knowing that first will spin?
Let's assume we take a 1200 mile trip and you get 28 mpg and my geared car gets 26 mpg (2-3 mpg difference). You burn 42.9 gallons and I go through 46.2 gallons. If we both start out with full tanks, we both stop for gas a minimum of 2 times. (maybe more if one of downs a Big Gulp and needs a pee break. ). Even if my geared car is reduced to 25 mpg, I can still make it on 2 stops. A 400 mile range is typically longer than I want to drive non-stop these days, but I could do it in my youth if I had to.
I think the non-geared car feels more relaxed at 75 mph than my geared Z51, so there is that benefit.
Old Nov 17, 2009 | 11:41 AM
torquetube's Avatar
torquetube
Actually, a 4.10 would come in handy on the street in stop-and-go traffic, where even the Z51-ratio 1st is too high. Everyone else is idling forward at 3mph, and the C6 can't quite go that slow without getting on and off the clutch.
However, I don't think anybody in history has bought a 4.10 for that reason.
Old Nov 17, 2009 | 04:01 PM
ALLBlackC6's Avatar
ALLBlackC6
I definitly need some better rubber to make the proper assesment. I still like my ability to carry gear though while a geared car would be shifting.
Old Nov 17, 2009 | 05:28 PM
3 Z06ZR1's Avatar
3 Z06ZR1
A big factor is if your a Z-51 or base transmission. The first three gears are 10 percent lower in a z-51 and 5th and 6th are lower also. So the 4:10's are shorter in the z-51. Because of the lower gears in the transmission. The 3.42's with the base tranny's .5 6th ratio are very high.
Example 92mph is 2k with the base, even with my 3.90's it is still
83 mph. where as 4:10's are only 67 mph at 2k with a z-51. HUGE difference here.
To me as I do more highway driving and 67mph @ 2k I would not like.
390's are great with the base tranny. Allows me a 10.37 first with
still a 1.95 6th perfect for my needs!
Old Nov 17, 2009 | 07:48 PM
PCMusicGuy's Avatar
PCMusicGuy
Rock'n Blue 08 hinted at more of my concern. My car is a daily driver and I drive stop and go traffic, freeways, and interstates. My A6 with 2.56 gears can cruise the interstate at 27 mpg at ~95mph @ 2k rpm. I would like to see mileage numbers and noise level reports from a geared car at a similar speed.
I think gears is a highly individual decision. In my case, I can't see how they would possibly be good for me with how I use my car.
Old Nov 18, 2009 | 10:56 AM
SgtRod's Avatar
SgtRod
My concern with gears is what was stated earlier. I dont want to shoot out of the hole on the track but get smoked on the 100 +
Old Nov 18, 2009 | 11:37 AM
ALLBlackC6's Avatar
ALLBlackC6
I also drive on the highway alot, my z51 I could drive cross country if I wanted to, I think 82MPH was around 1800RPM's. The member who stated 4:10's only go 67MPH at 2K RPM's that just wouldnt work for me. So I guess it does just come down to personal preferance, people who like the lower gears are either drag racers or non highway drivers.
I just always heard people answer someone's question about which mods to start with with the answer "gears" feel like 100 HP.
Truth is for someone like me they would make my car almost undriveable.
Old Nov 18, 2009 | 01:22 PM
Ragtop 99's Avatar
Ragtop 99
Why would gears cause you to be slower over 100? I could speculate on a couple specific senarios such as if you redlined 5th and are forced to shift into 6th, but that's at the very limit of the car. BTW, I take this to mean a roll race. If you leave someone in the dust out of the hole, they need a ton more mph to catch you unless your races go for a few miles. I've beaten cars that trap 10 mph more than me by having a 1.60' to their 2.0'
You might see if there is data from 1/4 mile guys with their 1/8 and 1/4 mph. The H&C and FI guys are pushing near 100 at the 1/8. You could look and see if non-geared cars gain more mph than geared cars on the top half of the track. I wouldn't expect to see that result, but that would give you data to around 130 mph.
Old Nov 18, 2009 | 02:05 PM
dennis50nj's Avatar
dennis50nj
you wont , you will reach the 100+ sooner
To Higher Gear Ratio? Why?
