Ive been reading that the ls6 intake is alot better than ours. Is there anyway to get that intake on my ls2? I dnt wanna buy a fast, so how is it done?
I *think*, IIRC that the throttle body is the big issue. LS2's is electronic and has a different bolt pattern than the LS6's cable operated throttle body. Also, the LS2 is larger.
LS6/LS1 throttle bodies on Corvettes were electrically controlled, but they were smaller (78mm) with a different bolt pattern. I think some folks tried to install the larger LS2 throttle body (90mm) flange on the LS6 intakes. Not sure how successful they were. If you don't want to spend the $$$ on a FAST, just get the LS2 manifold and throttle body ported. There are several forum venders that can help you. You won't get the HP as a FAST, but you will get an improvement.
Doesn't the firewall have to be altered somehow to get a FAST to fit on an LS2?
Spinmonster mods the intake to fit, so no fire wall mods are required. He can also port the intake and TB for you at a very reasonable price. If you check the forsale forum FAST's show up pretty regularly.
