Air filter and polen filter question
Old Dec 1, 2009 | 04:58 AM
20vtt's Avatar
20vtt
Default Air filter and polen filter question
Hi guys, I'm looking for a little help in finding the exact parts I need to order. I changed the oil and oil filters on my '08 Vette when it hit around 7000 miles but I didn't change the air filter and polen filters yet.
The car is now just under 9000 miles. I want to order the parts in advance, since I need to have them shipped to Romania, so it might take a while. I had a look on a seller's website (Ecklers) , which I used before to order an exhaust system, but I'm not quite sure which parts I should order.
If anyone can help me out with the exact parts name, or links or anything, I'd really appreciate it.
Thanks!
Old Dec 1, 2009 | 09:13 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
You need to let us know if this is the base LS3 car or the LS7 equipped Z06.
Old Dec 2, 2009 | 03:10 AM
20vtt's Avatar
20vtt
Default LS3 engine
Right, sorry about that, it's the LS3.
Old Dec 3, 2009 | 07:48 AM
GOLD72's Avatar
GOLD72
At 9000 miles, I would be surprised if you really need to change these air filters. In normal environments, the engine air filter should be good for at least 30,000 miles. The cabin air filter is very easy to remove and inspect. At 30,000 miles, I simply used a shop vacuum to clean my cabin air filter and reinstall. I did replace the engine air filter at 30k since the power core design used on the LS3 and LS7 engines is difficult to inspect and assess its cleanliness condition.
Old Dec 3, 2009 | 12:24 PM
JoesC5's Avatar
JoesC5
Your car takes a ACDelco A3077C (GM part # 15776148)for the engine air filter and a ACDelco CF139 (GM part # 15848592) for the cabin filter. Also, you can use a WIX 24480, Purolator C25623 or a BOSCH C3722 for your cabin filter.
Old Dec 3, 2009 | 12:38 PM
20vtt's Avatar
20vtt
Thanks Gold72, I will probably take your advice and change it later, maybe when I get close to 20k miles. My mechanic told me I should change the air filter more often because we get a lot more dust here in our obscure little country than you guys get in the USA
Thx again,
Mihai
Old Dec 5, 2009 | 09:55 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I would certainly be happy to help you out with them.
C6 Corvette Replacement Filters
15861929 – Air compartment filter – $46.49
This is the premium charcoal impregnated filter.
10342024 – LS2 Engine Air Filter – $17.92 each
The LS2 engine has 2 air filters per vehicle.
15776148 – LS3 Engine Air Filter – $93.20
15776148 – LS7 Engine Air Filter – $93.20
25940997 – LS9 Engine Air Filter – $124.51
89017524 – PF48 Oil filter – $5.27
19210283 – PF46 Oil filter – $5.03
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ $62.71 shipped
The UPF44 fits the 05 LS2 | 06 LS2. All other year C6 engines use UPF48R.
12626224 – UPF48R Ultra Guard Oil Filter - $8.88
Old Dec 6, 2009 | 04:13 AM
Devereaux's Avatar
Devereaux
You might want to consider putting in K&N air filters. There is a K&N cold air intake, but I just did the filters in the stock shrouds (LS2 - took 2 filters). Now when the filter gets dirty, or your mechanic thinks they are dirty, you only wash them, dry them, then reoil them and you are back in business. Also they are suppose to catch dirt really well, and flow air better.
Old Dec 6, 2009 | 11:23 AM
20vtt's Avatar
20vtt
Thanks, email sent to Gene.
Regards,
Mihai
Old Dec 9, 2009 | 08:52 PM
Gene Culley
Regards,
Mihai
Thank you for contacting me.
To Air filter and polen filter question
