aftermarket piston !!! help
Old Dec 6, 2009 | 05:39 AM
LS3_08's Avatar
LS3_08
Default aftermarket piston !!! help
Hi guys, i decided to fix my engine, i would need a new set of pistons, what is your recommendations?? i have stock LS3 engine not stroked but with ( intake manifold/TB/CAM/HEADERS/EXHAUST/AIR FILTER). I need reliable pistone(as on the stock ones it did breake cuz of the clearence problem).
Also, can you guys tell me what is the bore for the stock LS3 engine ? and what size do your recommend to order?
Old Dec 6, 2009 | 10:07 AM
SpinMonster's Avatar
SpinMonster
Stock pistons 4.065" and the pistons would depend on the finish hone you do.
Judging from your questions, I suspect you havent dont this before and if you are paying to get it done, have the engine builder source the parts so he is responsible for both parts and labor.
Old Dec 6, 2009 | 10:57 AM
3 Z06ZR1's Avatar
3 Z06ZR1
I'd say a new shop too! Wouldn't you Spin! Is this a cam change gone bad?
Old Dec 6, 2009 | 04:49 PM
Public Enemy's Avatar
Public Enemy
is the piston damaged because by installing a camshaft with huge lift and not checking the piston to valve clearance?
please specify what is the purpose of the vehicle and will there be any power adders.
if your going to daily drive the car with no power adder, it wont be a good idea to put forged pistons as they wear out faster than cast pistons due to less silicone and extra clearance. Not to mention you need to re-balance the rotating assembly as the weight of the piston will be different. Even if you were to install forged pistons for this setup i would recommend the 4032 forging as they dont wear as much as the 2618 alloy
If you going nitrous or FI than forged pistons is a good idea as it will take more beating and will handle detonation.
thanks
Old Dec 7, 2009 | 01:58 AM
LS3_08's Avatar
LS3_08
actually, i resone for the piston cracking is not clear. but from what happened we suspected that the reson is the clearence. the cam i added is a tested cam (G6X3) and had no issue with other owners as i red in many threades, when i got it on my car i got this problem ( i cant say they sent me the wrong cam cuz i am not sure), but i am going with a forged piston so if this was the problem i wnt face it again with the forged pistons.
Old Dec 7, 2009 | 02:00 AM
LS3_08's Avatar
LS3_08
we dont have such an engine builder who doe the order and fix parts together. i have to done the proper parts order for my application my self then give it to him, that is why i am asking the way to do that
Old Dec 7, 2009 | 04:50 AM
Public Enemy
if it was a clearance issue than it has nothing to do with the stock or forged pistons. To prevent the problem of a piston cracking just make sure P to V clearance.
The forged piston is better than cast in handling more beating, detonation and knock. If your car has none of these issues i would say go the cast pistons. Its your preference in the end of the day.
Old Dec 7, 2009 | 06:15 AM
LS3_08's Avatar
LS3_08
P to V clearance depends on what??? isn't it on the cam lifting? cuz as a stock car the car is so fine even with a smaller cam it was ok?
i appreciate your help
Old Dec 7, 2009 | 09:09 AM
Public Enemy
the more the lift the further the valve goes.
I know this issue, thamer told me about it earlier and i told him i have an ls7 engine for sale is your interested.
thanks,
mahdi
To aftermarket piston !!! help
