Insubordinate gauge cluster.
Go out to start the Vette the other day, and now, randomly, the gauge cluster wont sweep, none of the needles move whatsoever. Fuel, Tach, Oil Pressure, Coolant Temp, all flat. The cluster still lights up, as do all the fault lights right at start up, and the DIC (when cycled through) still reports all the proper parameters, like temps/pressures, range left on the fuel tank, etc.
So whatever is wrong is with the cluster itself, not any of the sensors/sending units. And it has power, because it's lit up, odometer works, etc.
Any ideas? Is there a specific fuse just for the cluster?
under the toe-board.
Remove the carpet and toe-board covering to access the fuse block by pulling at the top of each corner of the panel.
Open the fuse block cover to access the fuses.
You can remove fuses using the fuse puller.
There is a fuse labled CLSTR/HUD which I suspect relates to instrument cluster and HUD. You didnt state whether your HUD was still working or not......
I only posted first as it was dumping rain, I have no garage (that fits a car), and I didn't want to sit outside with the doors open while I fiddled around with fuses and manuals.
Except the needles. Wtf? I really hope I don't have to dismantle my dash to try and chase this down. I don't know the inner workings of these cars nearly well enough to discern what might cause the gauge needles, and only the needles, not to operate. I could see if it was juts one of them, but all? What's the common denominator?
There's just been way too many things go wrong for a normal car.
All of this comes from looking at the service manual's wiring diagrams for the instruments.
If I were you the first thing I would try is pulling the instrument panel out of the dash (not nearly as hard as you might think) to make sure I had a good connection at the C2 connector as it's the one that carries the engine speed and vehicle speed info.
for reference:
The C1 connector handles (I'm not listing everything):
- panel lighting & dimming
- hazard flasher signal
- oil temp sensor
The C2 connector handles: (ditto)
- battery voltage
- engine speed
- vehicle speed
- brake fluid level
- parking brake signal
Without removing anything (yet) by playing around you might be able to use the above to isolate something
Oh yeah, if you do take the panel out heed the manual's call to not lay it face down for more than 15 minutes. Doing so can damage the gauges.
Z//
If you do attack the gauge removal, here's a how-to:
http://forums.corvetteforum.com/c6-c...many-pics.html
I've had mine out twice and it's pretty easy. Just remember to move your steering wheel all the way towards you and all the way DOWN towards the seat as you'll need every bit of room for the gauge unit to clear the dashboard overhang.
Z//
Thanks much.
