Feb 20, 2015, 06:13 PM
See related guides and technical advice from our community experts:
Browse all:
Exterior How-Tos
automated bleed vs manual bleed
Dec 10, 2009 | 01:31 PM
Cruising
How do change the brake fluids? please help
Dec 10, 2009 | 01:39 PM
Quote:
Originally Posted by
GotVette?
with a powerbleeder from ZIP products it's a easy one man/woman job, a turkey baster will help you on the way too, just suck out the brake res add new fluid FOLLOW the directions that come with the bleeder MAKE SURE the caps on right and you really don't need all that much PSI in the bleeder you can always give it a couple more pumps when needed, so don't go crazy pumping it up!
Dec 10, 2009 | 01:41 PM
Also the the order in which you bleed them is not the normal order for most cars. Sorry, I don't have the correct order in front of me right now.
Dec 10, 2009 | 02:03 PM
Cruising
should i have the car on for the abs?
Dec 10, 2009 | 02:21 PM
the only way I know of to bleed the ABS is with a Tech2. There is not enough fluid in the ABS to make a difference. I would not worry about it.
Dec 10, 2009 | 03:34 PM
Cruising
Dec 10, 2009 | 03:38 PM
Cruising
is that a programmer?
Dec 10, 2009 | 03:57 PM
TechII is multi-thousand dollar diagnostic tool used at the dealership and some shops.
-D
Dec 10, 2009 | 04:06 PM
St. Jude Donor '08-'09
if your just flushing the fluid, start with the right rear, then left rear, then right front, the left front.
if you have air in your system, you might not be able to get the air out of the abs module.
a poor mans to get the air out would be to bleed it, then go out and jump on the brakes, activating the abs a couple times, then re-bleed.
-carl
Dec 11, 2009 | 03:11 PM
Cruising
carlrx7
-carl
How much fluid is in the abs? Can i get air into the abs if bleed incorrectly?
Dec 11, 2009 | 03:27 PM
carlrx7
-carl
Correct order is right rear, left front, left rear, right front. The vettes brakes are on 2 different circuits.
Dec 11, 2009 | 06:27 PM
sorry to repeat my input from the other thread, but this may be a case of "if it isn't broke don't fix it". the chance of causing a problem could be greater than the chance of preventing one. In any case I hope I'm wrong and it goes smoothly.
Dec 12, 2009 | 01:01 PM
GotVette?
no, and don't worry new fluid will go everywhere
