Seperating the M6 from the rear diff... help
Old Dec 14, 2009 | 12:48 PM
ruf455's Avatar
ruf455
Default Seperating the M6 from the rear diff... help
Ok, 05 M6. Pulling the transmission. I have four bolts removed from the transmission to diff flange. Are there more? I only see the four and she will not budge. HELP!
Old Dec 14, 2009 | 01:02 PM
MachineWorks's Avatar
MachineWorks
There are 5 bolts.
Old Dec 14, 2009 | 01:11 PM
ruf455's Avatar
ruf455
Two nuts on studs up top, two nuts on each side right and left...and the 5th?
Old Dec 14, 2009 | 01:23 PM
vetracer's Avatar
vetracer
Did you get the two nuts underneath near the leaf spring?
Old Dec 14, 2009 | 03:38 PM
ruf455's Avatar
ruf455
I guess I am an idiot. Any one have some pictures? I just see four, not five, not six, not two nuts by the leaf spring... if there is more, I will get the dumb *** award of the day.
Old Dec 14, 2009 | 04:33 PM
glennhl's Avatar
glennhl
I hope you find them, but don't feel bad. I did a clutch on my 94 Z28 years ago and I had a great "how-to" on the internet that said there were 6 bolts holding the bell housing onto the engine. Truth was there were seven and I tried and tried to get that bell housing off until I finally found the 7th bolt. If it's not budging, I'm betting there is 1 or 2 bolts still holding it on.
Good luck,
Old Dec 14, 2009 | 08:17 PM
haljensen's Avatar
haljensen
Thought I would help a fellow Austinite out and got the Helms Manual out. No help! Really vague pictures and descriptions. Ex.; "remove the differential to transmission bolts and nuts." From their poor illustrations it looks like 8 fasteners trans case to diff case!
Are you using a Helms shop manual?
Old Dec 14, 2009 | 08:28 PM
Nasty C6's Avatar
Nasty C6
there's one on the very bottom,always pull it first so you dont miss it. cause i'm sure it's sitting on the jack
Old Dec 14, 2009 | 08:52 PM
ruf455's Avatar
ruf455
Ok. It's NOT on the jack. It's on the cradle sitting on the ground. I don't have the Helms, I have Mitchel on Demand access (It has all of GM's reference pics and procedures). The pictures are just as vague as the manuals...just online. Yeah, it's shows way more bolts that are actually present. And the "one" on the bottom...well. I pulled one that appeared to have have gone into the case...but I can't tell, nothing gave. Maybe, someone could post a picture of the "bottom" bolt? Please?! Or better, post a pic of all the bolt locations? I am usually pretty fair at R&R work...but this is embarrassing.
Old Dec 14, 2009 | 09:04 PM
ruf455's Avatar
ruf455
These two nuts, on each side.
I don't see the bolt on the bottom. The black bolt in the photo here is not part of the equation.
what is really pissing me off, is that I just realized break fluid has already dripped on the top of my T/A at by this point...awesome.
Old Dec 14, 2009 | 09:46 PM
haljensen's Avatar
haljensen
The Helms procedure calls for removing everything from the trans/differential before seperating them.
Old Dec 14, 2009 | 09:56 PM
jxhunte's Avatar
jxhunte
According to my 2006 Corvette Service Manual, Vol 3, there are five fasteners that secure the transaxle to the transmission. Each fastener is tightened to (37 lb ft). There are two bolts that go from the top side of the transaxle to the transmission. There is one nut on the bottom side of the transaxle that fastenes to a stud from the transmission. There are two nuts on the transmission side that fasten to studs protruding from the transaxle. (Two Bolts and three nuts that attach to studs, a total of 5 fasteners).
Old Dec 14, 2009 | 10:25 PM
cencalc6's Avatar
cencalc6
here's a few pics when I swapped out my 05 diff with an 06+ diff
There are 4 bolts and 1 nut that needs to be removed to seperate the diff from the tranny.The bottom nut is really tucked in there, you will need an open end wrench to reach it pita! Hope these pics help
here's a pic of both 06+ and 05 tail housings
-On the 2006+ diffs they have 6 bolts and 2 nuts
-2005 diffs have 4 bolts and 1 nut
06+ Left vs 05 Right
Old Dec 15, 2009 | 08:05 AM
ruf455's Avatar
ruf455
Cencalc6, Thank you for the picture!!
Old Dec 15, 2009 | 09:09 AM
haljensen's Avatar
haljensen
The '05 Helms illustrations are of the '06 trans/diff!?!? 8 fasteners shown.
Lots of wrong info in the '05 Helms? Looks like Helms uses a cut and paste by non-mechanics.
So far I've found wrong info on;
The intake manifold removal; "Drain coolant required".
Illustration and directions for brake removal/install are wrong.
Trans/differential removal/install illustration and directions wrong.
Old Dec 15, 2009 | 10:28 AM
cencalc6's Avatar
cencalc6
No problem
Old Dec 15, 2009 | 01:28 PM
MachineWorks
Like I said 10 post a go, 5.
To Seperating the M6 from the rear diff... help
