Difference between stainless brake line co.'s?
Old Jun 29, 2010 | 07:47 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Originally Posted by SUB VETTE
With the OEM lines overtorqued, how hard is it to remove them, and what are the odds that the fittings will be damaged. I'd hate to get into the middle of this job and find that (a) I can't break the fitting loose; or (b) Once loose I find that I've got a cut and flare job on my hands to replace a damaged fitting.
The front passenger side seems to almost always be the culprit. I had to cut and flare my line as the fitting was toast.
This thread will provide some very useful information if you have issues. I also have a set of brand new Stoptech front stainless lines if you're interested.
http://forums.corvetteforum.com/sout...formation.html
San
Old Jun 30, 2010 | 05:27 PM
mittens's Avatar
mittens
there was a thread on here at one point saying the stock lines are braded something and rubber out side, so the factory ones are not streatching......
Old Jun 30, 2010 | 06:14 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
We are one of the only companies to get rid of the Banjo style block on the caliper. It removes the extra sealing surface, simpler, and less chance of knocking them lose, rocks, chunks of rubber and other stuff can rotate a banjo bolt enough to cause a leak.
Randy
www.dougrippie.com
Old Jun 30, 2010 | 06:16 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Most hydraulic "rubber" hoses have some reinforcement so they are rated for the pressure they are being used for. There is more flex, you can almost watch it.
Randy
Old Jun 30, 2010 | 06:20 PM
Chris_B's Avatar
Chris_B
Randy
Very true. OE rubber lines usually use nylon or fiberglass, with some even using a little stainless steel. However, they are a long way from the stiffness of a full stainless steel overbraid. Not to mention the water vapor intrusion that rubber allows over time that Teflon does not.
Chris
Old Jul 2, 2010 | 11:04 AM
Mike Yeager@Eastcoast Performance's Avatar
0Mike Yeager@Eastcoast Performance
Former Vendor
Randy
The Corvette Rubber brake lines DO NOT have any stainless braid in them, they use alittle nylon to keep it from blowing apart...
Chris
Hi Chris, the Russell Stainless Brake Lines we sell actually have the stainless braid woven into the rubber part of the line, its not just an overlay...Then there is a clear coating over the top of the stainless braid to keep out oil and dirt, which allows these lines to last much longer...
Old Mar 22, 2011 | 09:26 PM
StKnoWhere's Avatar
StKnoWhere
This needs to be clarified. The only problems I've seen with Corvette fitments has been the same for the full-size GM SUV's. According to GM production engineers, a few years back GM started to over-tighten the chassis-side fittings due to supplier issues on the SUV's. They had a few cars dripping brake fluid on the showroom floor, which was obviously unacceptable. After going around and around with their foreign supplier, they found the best sure-proof solution was to just wrench them down a bit more past the specified torque value.
This "advanced production technique" was carried over to the Corvette production line as well. The problem is that the threads on the hard line flare fitting are often damaged and the bulb flare itself is also deformed. While the original lines will go back on (they are naturally distorted in a matching fashion), new lines can be difficult if they are made to tight tolerances -- as Goodridge lines are. That said, even a brand new rubber line from the factory is nearly impossible to thread on without chasing the chassis fitting threads with a die and filing down the portion just below the threads as it has become oversize due to bulging. In a rare case or two, some have had to cut the brake line tube, put on a new flare fitting and re-flare the tube. This situation was not caused by Goodridge. The hose ends are not "soft" at all and they are not sloppy enough to go over the deformed chassis fittings if they happen to be damaged enough.
Goodridge is a top-notch global brake line supplier. Their lines comply to the most strict German TÜV standards as well as US DOT FMVSS 106. They have a TON of OE accounts in the automotive, marine and snow machine industries. They also supply a HUGE number of F1, F3, NASCAR, WRC, Touring Cars, World Challenge, etc., etc., all over the globe. They are included in all AP Racing and Brembo brake upgrade systems. And, they are guaranteed for life.
Side note: The U.S. DOT does not "approve" brake lines. They set the standards that manufacturers must comply to or face fines/imprisonment. Brake line manufacturers must do their own testing. This data must be solid enough to stand up in court, should the need ever arise. When considering lower cost lines, one might wish to request certified data from an independent lab from the pressure, flex and whip tests. Let the buyer beware.
Chris
Sorry to revive an old thread, but thanks for the above -- very helpful.
Probably a stupid question but how do you stop the brake fluid from draining while chasing the threads on the chassis side fitting?
Old Mar 22, 2011 | 09:27 PM
StKnoWhere's Avatar
StKnoWhere
Originally Posted by Mike Yeager@Eastcoast Performance
The Corvette Rubber brake lines DO NOT have any stainless braid in them, they use a little nylon to keep it from blowing apart...
FYI - nylon will also block moisture penetration.
Old Mar 22, 2011 | 09:31 PM
Turbooo2u's Avatar
Turbooo2u
Originally Posted by HC Mechanic
I know Goodridge makes really nice lines, I have used them on a lot of the race bikes I've built. I'm sure the Stop Tech's are good as well
I have the Goodridge on both my Vettes. They got rid of the slight sponginess in the pedal.
