Another Key Fob Programming Question
Old Dec 16, 2009 | 04:40 PM
important's Avatar
important
Default Another Key Fob Programming Question
I tried to do my research this time before posing this question.
I keep finding threads on programming fobs IF you have an additional working fob. I just have the one fob...
If I change the battery (which I also dont know how to do) how do I go about re-programming?
Thanks!!!
Old Dec 16, 2009 | 04:43 PM
timd38's Avatar
timd38
If it works and you change the battery, it will still work after the new battery.
Old Dec 16, 2009 | 09:40 PM
important's Avatar
important
Thats cool, now how do I change the battery...
Old Dec 16, 2009 | 10:01 PM
BowTieBlood's Avatar
BowTieBlood
I don't know how to reprogram the key fobs, but to change the battery you just pop the fob open and swap it.....or better yet you find a Batteries Plus or similar shop and give them $7 for a new battery and they'll do it for you.
Old Dec 18, 2009 | 02:21 AM
important's Avatar
important
Just kinda jimmy it open? Any pointers?
Old Dec 19, 2009 | 03:47 PM
Phoenix FRC's Avatar
Phoenix FRC
pointer, yep.. look at it.
The top where the key ring goes thru it, has a little opening gap for you to use a flat head screwdriver. just gently open it a little, then slid the screwdriver around it and it will pop open, its real easy.
My battery is a CR2450 for my 2000 C5.
Once I figure out how to program it, i'll post again.
Old Dec 19, 2009 | 07:48 PM
cclive's Avatar
cclive
On the '05 -'07 fob, a nickel is the perfect prying device to open the fob. The battery is a CR-2032, which is about the size of a quarter, available at almost any big store near you....supermarket, target, Walmart etc. $3.
No programming is necessary after replacing the fob battery or even the car battery. If you ever need to re-program fobs, my fob programming instructions are in the FAQ section here:
http://forums.corvetteforum.com/c6-c...tructions.html
Old Dec 22, 2009 | 05:20 AM
important's Avatar
important
Well, I'll be dag goned. It worked. Scuffed up the key fob a lil while prying it open Besides that, Im happier than a etc. etc.
To Another Key Fob Programming Question
