09 clutch issues. any input?
Old Dec 16, 2009 | 10:10 PM
609thomasm's Avatar
609thomasm
Default 09 clutch issues. any input?
just turned 2000 miles today. went up thru the gears fairly aggressively and in either 3rd or 4th the clutch pedal stayed on the floor. this happened to me a couple times before. almost seems like the clutch wont engage at the higher rpm range. anybody else having this problem.
Old Dec 16, 2009 | 10:29 PM
bps999's Avatar
bps999
I have not had this happen, but this issue is often discussed on here. One of the main recommendations you will get is to keep the clutch fluid clean by the "ranger method", named after a forum member who has apparently done considerable research on this subject. Info can be found at www.rangeracceleration.com under "clutch care", as well as on many other threads on this forum.
