SKF Bearing install
First thing I found out is that you can not put longer studs in without removing the hub assembly.
Well, let me tell ya, it isn't a simple bearing swap. You have to disconnect the lower ball joint and on the back remove it and the axle shaft, and the means all the associated joint connections.
I never drive the car in the snow, can't remember the last time I drove in the rain, I wash the bottom almost as much as top, and let me tell ya, the torx bolts that hold the bearings in are a real challenge to remove.
Here are a couple of before and after shots.
