c6 fuel tank help
Old Dec 29, 2009 | 02:32 PM
beemc's Avatar
beemc
Default c6 fuel tank help
on the driver side fuel tank there are a couple o-rings and spacers that seal the crossover tube and when i removed the tube the o-rings and spacers fell out . when i reinstall the crossover tube what order do i need to put them in there is a small spacer , a bigger spacer , a yellow o-ring and a green o-ring
Thanks in advance
Old Dec 29, 2009 | 05:16 PM
Nasty C6's Avatar
Nasty C6
they only go on one way,....look close at the pieces,one big o-ring and sleeve,and one smaller o-ring and sleeve,the o-rings go on first,then insert the sleeves,they go on bevelled side out,make sure the cross-over lines are clipped into the end of the cross-over tube properly.good luck.
Old Dec 29, 2009 | 06:36 PM
mattsc's Avatar
mattsc
OH BOY....just completed this the other day.(Install a Zo6 pump)WHAT A BIT*H. Obviously you know once all seals and o-rings are on correctly you must connect the two small black crossover tubes before closing and sealing the metal crossover.I did this with the complete drivtrain intact ..it's tough and I made a custom bar to hold pressure on the metal tube upon reinstallation (reinstalling is much harder than removing) Be carefull it's easy to damage the seals and o-rings .I have a complete new G.M. kit if you need it,and might have the diagram at the shop. P.M. me if you need the diagram tomorrow morning.
Matt
To c6 fuel tank help
