Stroker LS3 dyno results!
Dec 30, 2009 | 12:07 PM
4" Crank
4.060 bore
Stock ported LS3 manifold
Stock LS3 heads
G6x3 cam
Longtube headers
11.5:1 CR
Pump gas
Dec 30, 2009 | 12:10 PM
very impressive for stock heads no doubt- great work LG!
What's the CI? 418?
Thats some beastly torque.
Dec 30, 2009 | 12:25 PM
should be 415-416 Cubes ~ I think the final bore was a cleaned up 4.065!
I REALLY like the 400 rwtq @ 1600 rpms
Dec 30, 2009 | 01:16 PM
What kind of deal can I get on this LS3 stroker Louis?
Dec 30, 2009 | 01:23 PM
Quote:
Originally Posted by
dsp300c
LOL! i wonder what it would make with some good ported heads instead of stock ls3s..
Dec 30, 2009 | 01:31 PM
WhiteLightning_
Exactly. I can use my TF heads. Joe uses TF 235s on his LS3 stroker.
Dec 30, 2009 | 01:35 PM
This was a total budget build. The LS3s have enough airflow to produce that kind of power. The TF 225s will make good torque, but not much more peak HP, and rev range will be lowered from 69-7200 to 60-6200 rpms. I would recommend going to a 245 and a bit more cam, but the 225s are not going to produce the results we are looking for.
Dec 30, 2009 | 01:36 PM
dsp300c
so when does your car go under the knife?
Dec 30, 2009 | 01:38 PM
Louis @ LG Motorsports
i think if push came to shove, andrew could sell his heads and recoupe some of the money towards 245s though. I know hes ITCHING to run a 9 on motor
Dec 30, 2009 | 01:40 PM
WhiteLightning_
Depends when louis has time and what the cost is for the stroker ls3 with TF 245 heads and a bigger cam. Send me a quote louis.
Dec 30, 2009 | 01:42 PM
dsp300c
depends when louis has time and what the cost is for the stroker ls3 with tf 245 heads and a bigger cam. Send me a quote louis.
do it!!!!
Dec 30, 2009 | 02:28 PM
dsp300c
if u are serious, send me a realistic quote on your 225s please... intake too if u are replacing it. dont want the cam, its too big for my pop's.
Dec 30, 2009 | 02:42 PM
STROKD
Depends on the quote and if my money I have saved can cover it.
Dec 30, 2009 | 03:06 PM
Why do you think the torque dips down at 2k?
Dec 30, 2009 | 03:25 PM
Its normal tuning for header primary length and intake runner length. I can move that torque dip around with intake/header lengths and cam IVC. Its pretty stardard issue, you just NEVEr see it on other dynos, because they never dyno at IDLE....
Dec 30, 2009 | 04:09 PM
St. Jude Donor '12 thru '26
That's got to be FUN
Dec 30, 2009 | 05:12 PM
Dec 30, 2009 | 07:41 PM
416
Dec 30, 2009 | 07:45 PM
St. Jude Donor '10
Makes me wish you guys were closer.
Dec 30, 2009 | 07:54 PM
Makes me wish I had a better paying job... You guys should raffle of some shortblocks.
